HI, Yes, I just droped mine in too. Does that wire glue seem to add any resistance? I was concerned that just the QTC would add enough resistance to dimm the light, but I can't tell with my naked eyes. The drop it in method is temporary for me. My idea is some sort of brass disk sandwich with a foam washer in the middle[the meat]. The QTC would go in the hole in the foam washer. The foam washer would be larger than the brass disks to prevent shorting against inside body walls. The brass disks are glued to the foam washer and keep the QTC in. The foam washer should be softer than the QTC and about the same thickness. I think some shin stock would make some nice disks and would keep it thin. I like your glue idea though, sure sounds simple, hope it stays in place, keep us posted. This sandwich may also work with tailcap spring, but I wonder if the spring resists compression enough to compress the QTC. How much pressure does it take to compress QTC? We are really cranking down on it with this springless twisty design!
