cp2315
Got it today. Love it! I am using 2 x efest 16340 cells. It is bright! solid and quite compact!
My Alpha also has the "flicker" but it's such a minor issue to me that I haven't bothered to contact Elzetta about it.
They turn things around pretty quick, just sayin'
I guess I should. It doesn't bother me really but for $140 it might as well be perfect.
Just got my first Elzetta today thanks to their tax day give way and so far I really like it. I had looked at them when they first came out but never did purchase one despite them being made in the next county over.
I do have one question for you guys who have more experience with them. Is the tail cap supposed to be loose on the threads and have some up/down side-by-side movement when loosened? I have the hight/low tail cap on a bravo body with an AVS head. When loosened for low mode, I have to give it a half turn to get it to not go into high mode when I press the tail cap for on or off because otherwise the whole tail cap will move down enough to activate high mode. I read thread the thread and it seems to be a common complaint about the tail cap threads but I was just wanting to make sure the tail cap was functioning correctly.
How did boring get more thread engagement?
In my hands, I have three Elzettas. One is stock, a second one was bored by Oveready a few years ago, and the third one was bored as part of their most recent batch.
The threads of the stock and recently bored one are the same. The one previously bored had an additional o-ring channel machined into the body, leaving three (or so) threads. The tailcap, at least my high/low ones, only engages three (or so) threads so this additional channel should't affect thread engagement. I would also prefer more engagement, but it does work adequately well as it is.
My guess is that if the threads were a tight fit, then it wouldn't be possible to tighten or loosen the tailcap with one hand....something that's much more tactically important.
Given the choice between tight, with two hands required, and loose, I choose loose.
Good point. I guess the square threads may be a lot stiffer to move and require 2 hands.
Both good points I hadn't considered. There could have been more threads though that way when loosened there still would have plenty for the tail cap to engage and not rock as much.
