45/70
From what you guys are saying, it's clearer to me now, how the Sanyo Harmolattice cells would be a viable alternative to regular LSD cells. I don't run my newer cells in low drain devices. I just use older cells that they have replaced, or "crap cells". In these devices, they've always worked quite well.
Most devices that I use my newer cells in all draw enough current that, I suppose anyway, is why I've not run into the problems Ziemas and others here have experienced. Thinking more about how I use AAA cells, I run proportionately higher current from them than my AA's, eg. 2C+ at times, and I'm sure that has a lot to do with their seemingly short cycle life.
Justin Case, I see my attempt at a humorous post failed. Sorry about that. I'm sure you and many others here have more knowledge than I about cell chemistry, behavior and so on. I was just messin' wid ya!
So anyway, thanks for the kind words, and lighten up man!
Dave
Your snide remarks demonstrate a remarkable ignorance, fairly typical of UI people like yourself. I note that you seem incapable of discussing the factual aspects of the definitions of the terms you are using. The fact is that formation <> growth, and it is clearly grain growth that is the operative mechanism. Your "proof" that "crystalline formation" is correct terminology is an appeal to authority argument, which is fallacious. I can find plenty of references that refer to grain growth, not "crystalline formation", from DOD and academia. So what.
Not sure what endeavor you refer to. If you mean enlightening you, you are finally correct in something -- it is hopeless.
Dave
