Not sure if this thread is still considered alive or not, the last post being 6 months ago...
Sanyo started the ball rolling with low self discharge NiMh cells with the introduction of their Eneloop cells. I, along with several others, have been testing these cells for roughly a year now and they seem to be holding up to the manufacturers claims.
I am only going to project out to the year mark because I am going to be using my cells. Someone else can do the 1 year testing…
Tom
OK; I decided to buy some and try them out myself. Bought 16 Eneloops from Thomas Bros.
Being Thomas Bros, I couldn't help but notice the Imedions too...so I bought 16 of them too.
Initially, I wasn't all that impressed. Off the shelf, all the batteries took a substantial charge;
For the Imedions, varied from 431mAh (not bad) to 1566mAh (not good at all); For the Eneloops,
varied from 621mAh (not particularly good) to 1263mAh (pretty poor, IMO). Although the
Imedions had the worst datapoint, overall they fared better than the Eneloops.
I then measured the first full-charge-cycle discharge capacity of each cell, then proceeded to
cycle them several times to break them in, as NiMH typically show a healty growth in capacity
with several break-in cycles. While neither set of batteries showed a dramatic improvement after
several cycles, the Imedions again won (slightly) over the Eneloops, showing only about 5%
growth in capacity, versus about 10% for the Eneloops (or, rephrased, the Imedions were closer
to providing full capacity more quickly).
I then put the fully-charged batteries aside, intending to test charge retention after a few months.
The days passed; the moons waxed and waned; the rivers rose and fell; the snows came and
went; Spring arrived. Merde! My batteries! After a full year, I "remembered" my batteries. Figuring
I had now toasted 32 expensive (well, relatively speaking) LSD batteries, I retrieved them and ran
them through their paces.
I stand
amazed. After 1 year sitting neglected and ignored, my 16 Eneloops all boasted 1725mAh
to 1780mAh residual charge!
One Year! Talk about
consistent performance, Wow! The Imedions
fared almost as well, with remaining charge varying from 1665mAh to 1895mAh, with one outlier
cell "failing" with less than 300mAh remaining charge.
All testing was performed on my LaCrosse BC-900s (0.5A max discharge, etc., and so forth).
In the table below, the columns mean:
* Cell -- Cell (or "battery") number, 1 to 16
* Initial -- Initial 200mA charge
* cy1 -- First capacity cycle: 200mA discharge from full charge, recharge at 500mA
* cy8 -- Eighth capacity cycle: 500mA discharge, recharge at 1000mA
* 1yr -- 500mA full discharge capacity after 1 year after cy8 charge
* 1ycy1 -- 500mA discharge capacity after 1yr recharge
Here are my Eneloop/Imedion charge capacity and charge retention results.
Maha Imedion AA 2100 April, 2008 buy
Cell.Initial..cy1....cy8....1 yr..1ycy1..
#01 | 0813 | 2250 | 2320 || 1770 | 2300 |
#02 | 0468 | 2240 | 2340 || 1730 | 2290 |
#03 | 0446 | 2210 | 2300 || 1730 | 2240 |
#04 | 1566 | 2280 | 2280 || <300 | 2260 |
#05 | 0433 | 2250 | 2360 || 1845 | 2300 |
#06 | 0441 | 2270 | 2380 || 1895 | 2310 |
#07 | 0930 | 2250 | 2410 || 1550 | 2330 |
#08 | 0520 | 2200 | 2300 || 1720 | 2250 |
#09 | 0541 | 2250 | 2340 || 1650 | 2270 |
#10 | 0523 | 2250 | 2370 || 1855 | 2310 |
#11 | 0559 | 2290 | 2390 || 1825 | 2340 |
#12 | 0541 | 2240 | 2340 || 1720 | 2300 |
#13 | 0800 | 2270 | 2340 || 1810 | 2310 |
#14 | 0429 | 2180 | 2310 || 1830 | 2260 |
#15 | 0431 | 2220 | 2320 || 1665 | 2260 |
#16 | 0814 | 2200 | 2260 || 1855 | 2230 |
Sanyo Eneloop 2000 April, 2008 buy
Cell.Initial..cy1....cy6....1 yr..1ycy1..
#01 | 1188 | 1943 | 2170 || 1780 | 2140 |
#02 | 0643 | 1870 | 2110 || 1760 | 2060 |
#03 | 0908 | 1920 | 2130 || 1765 | 2090 |
#04 | 0733 | 1980 | 2120 || 1770 | 2100 |
#05 | 0768 | 1930 | 2150 || 1750 | 2110 |
#06 | 0621 | 1842 | 2100 || 1720 | 2060 |
#07 | 0748 | 1888 | 2120 || 1725 | 2080 |
#08 | 1210 | 1971 | 2150 || 1720 | 2110 |
#09 | 0720 | 1890 | 2140 || 1730 | 2120 |
#10 | 0724 | 1892 | 2140 || 1745 | 2090 |
#11 | 0650 | 1920 | 2170 || 1755 | 2120 |
#12 | 0730 | 1960 | 2150 || 1735 | 2110 |
#13 | 1263 | 1920 | 2150 || 1755 | 2120 |
#14 | 0687 | 1871 | 2120 || 1730 | 2080 |
#15 | 0692 | 1947 | 2170 || 1775 | 2130 |
#16 | 0713 | 2000 | 2190 || 1765 | 2150 |
I was very favorably impressed with how both the Eneloops and the Imedions performed, excepting
one "bad" Imedion (well, 31 out of 32 batteries ain't too bad, in my experience).
I don't care if "traditional" NiMH can provide higher per-cell capacity, this breed of LSD cell/chemisty
is clearly a winner, and far more practical to use, effectively matching LiIon cells for overall charge
retention (set aside and forget capability).
Overall, I give "first place" ever so slightly to the Eneloops for their more-consistent cell-to-cell per-
formance. But the Imedions (well, 15 out of the 16 of them) did manage about 10% more charge
capacity, which is significant and would I suspect place them "first place" in most folks' opinions.
Yay!
-RDH
