Avatar28
I haven't looked lately but if you have one up there the H.H. Gregg stores around here were selling the Eneloop 4xAA packs for like $7 or $7.50.
The main concerns would be:
1) High self discharge - How much capacity will they have left 1, 2, or more weeks after you charge them?
2) Lifetime - How quickly does the capacity decrease vs. time and number of cycles?
Yes and also the impedance of the cells increases and messes up the ability to deliver higher currents or even medium currents. Eventually only low currents give nearly the same capacity. The C9000 shows a brief number (1.68) on my AAA Duraloops right after starting to charge. Then the voltage shows 1.24 or what ever is normal at begining of charge. When it increases over 2.08 or so THEN you will see HIGH and it refuses to charge the cell. Need a lower pulsed current charger than the 2 amps.The main concerns would be:
Well i want to buy my first set of AA rechargeables, But i dont want to pay the shipping for the eneloops.
Is there any real difference in the quality of eneloops or the energizer rechargeables that i can get at walmart?
Or do you guys know where i can get some eneloops with free shipping?
Thanks,
Brian
Just because it's made by Sanyo doesn't mean it's LSD - Low Self Discharge or "Eneloop." Does anyone know for sure whether Sanyo makes non-LSD NiMH batteries?
Note that "black top made in China" Duracell precharged, or Rayovac 4.0 batteries are only a little less good than Eneloops. They're much better than non-LSD NiMH batteries.
To fishinfool, if you have a c9000, record the impedance test voltage for each cell and note changes over the long time. Keeping track of this will give you early warning of when a battery looses capacity at high current drains.
Would these be comparable to Eneloops since they are made by Sanyo? I saw some of these at walmart while looking for duraloops. Thanks.
I just bought some Energizer Recharge AA cells which I have not seen before. They are 2300mah, made in Japan, and they claim to hold a charge better than their 2450mah cells over the course of a year. I bought some other Energizer 2300mah NIMH cells several months back that had similar claims, and they work great. They both were not labelled "precharged" or "LSD", but they definitely do not discharge quickly.
Here are the break-in numbers on the 8 energizer 2300's I bought 2-3 weeks ago:
2272, 2270, 2238, 2276, 2295, 2276, 2260, and 2267.
We'll see how they do after a few months of use.
I've been buying different nimh brands just to see how they compare to my eneloops over time. So far I have Powerex 2700's, Energizer 2450's, 2300's, 2200's, Duracell 2450's, 2000 regulars, 2000 duraloops, Rayovac platinum 2100's, and Diehard (Sears) 2000's. I've been keeping track of everything and anything about these batteries so we will see how they do over time.
Man, I think I need a life. :thinking:
