I asked that earlier, and received a rather cryptic reply. I think it's a locker for Size15's shoes, LOL
:nana:
Got mine today. Very nice machining and annodizing. One area in the battery case where anno had been missed but that should not be a problem. The switch is a bit notchy right now and I'll see if that will smooth out with some use--I suspect it will. I haven't tested the waterproof (water resistant?) capabilities of the battery case but the rubber washer must be carefully aligned when torquing down the thumbscrews to be sure the washer is aligned properly.
I dropped a Nailbender Cree XPG (3.6 to 8.4 volts) into it and works fine...performs GREAT! Oh yes, I requested the blade option and purchased the Stenlight headband---perfect combo for me! I have a Scurion which I purchased this past Summer and I really like the two different beam dispersion patterns offered with the Scurion and I am thrilled to see that this may be offered in the Custom P60 Headlamp sometime in the future.
Overall, this headlamp compares very favorably with the Scurion but at a considerably lower pricepoint. This is a VERY nice headlamp.
Karl
The switch breaks in and gets way smoother!
When removing batteries I suggest neg end first as the tabs can snag the wrapper around the button on flat tops.
Thanks, Karl! That's high praise!
I came to the same realization yesterday with respect to the battery case, and started using contact cement (Permatex) to hold the rubber on the top of the battery case. It works very well, and is now standard. If you want me to glue the rubber, you could ship the headlamp back to me, I'll do it, and send it back. If you feel comfortable doing it yourself, that's the other option. I'm sorry I didn't realize it sooner!
Kevin
Nah Kevin, I can handle it! :thumbsup: I got the 080 screws in so, this'll be "cake"! As I said before, fine construction---I am very pleased!
Karl
