Allen head are the way to go.....
From looking at the pictures, and the channel that's milled out, It's just a board to make a connection from the postive terminal of the battery/switch to the positive spring on the dropin. The channel is most likely there to hold a piece of wire, with the part under the positive spring being an actual hard board (or it will just be a long, narrow board the switch/positive connection will be soldered to), with insulation around the edges, to prevent any short circuiting from happening.
~Brian
The side LED (which will go in the rectangular area, where the switch is) will likely be a flood LED, for general area and close up lighting. It probably won't be driven too hard (to keep it from being too bright up close). Probably a few 7135's to regulate the power going to it. ~BrianThanks Brian. Doesn't putting a side LED (that presumably isn't in drop-in form) negate any upgradeability benefit that might claimed from using drop-in module in the first place?
Got that Brian, but KevM has argued that using a P60 drop-in, overcomes (in his words, not mine) the same failing as all the other lamps so far: the LED's will be outdated in 3 months'.
So will that flood LED somehow be immune to going out of date then?
Oh.
Would make sense to mount it that way, in my opinion.
^^^ the flood thing is more like an optional running light I think.
I dont see why yer hating on it?
some people here have a few if not more drop-ins they would like to be able to use
in a headlamp host as well as their handhelds.
So, moving on, do you really have lots of drop-ins, all bang up to date, but all subtely diffferent enough, that its worth swapping between them for different jobs ???? I could maybe buy that logic (on a slightly obsessive level), but the upgradability thing strikes me as a red herring.
That's one of the two competing ideas. The other is a reflector-less drop-in. There's room, but barely. It all depends
on a reply I'm waiting for about the switch. Brian, I think you've got this thing figured out!
its not as elegant as some of the mainstream dedicated head/helmet lights out there
for sure but it serves a unique purpose.
I personally dont think other dedicated HL are inferior than this host. I just want to be able to switch modules rather than soldering in a new emitter or driver. I've used Lupines and other high end lights and they are beautiful.
Being able to select the module you want to
use or upgrade to is still the idea and the flood is an afterthought as there is extra
space due to machining and the switch.
Sorry Brian I was responding to Simples. I've edited my post to clarify.
I do understand the host and was arguing it's merits!
I've got a few diff modules I'd like to try in it- floody throwy etc.
That was the first plan (and still might be the case).The other is a reflector-less drop-in. It'll fit, but barely. It all depends on a technical point about the switch. I'm still waiting for an answer there.
With that said, I myself have been looking for a P60 dropin headlamp for a while, because I enjoy the user-friendly upgradeability, but they've all become vaporware in the end.
~Brian
