Fenix LD01 Repair
ryukin2000
Calgary
hi all, i have an older Fenix LD01 twisty light that stopped working on me all of a sudden. I believe it is a driver issue possibly something loose. I took the head apart and put leads to the pads and the LED lit up fine. when i put the leads to the driver battery side ,nothing happened. When the light is tightened down and i shake the light it turns on and off with each hard shake. sometimes it will stay on with a tap .i also cleaned all contact points and it didn't improve.
How do i remove the driver? doesn't look like i can from the top. its a solid shelf with 4 holes. from the battery end i don't see where i can use a tool to thread it out. Thanks.
