Yes, but that's not surprising - my E11 is rated by Fenix as 115 lumens, and my LD12 is rated as 125 lumens.Am I reading the output summary chart correctly, the LD12 max output is only 5 lumens more than the E11?
Great review! Not to sound stupid here, but why don't you want PWM.
That was also interesting the older model put out more light then the newer one.
Actually, regulated max output is about the same between my LD12 and LD10. It is just that initial output that had marginally higher, on NiMH.Great review! Not to sound stupid here, but why don't you want PWM.
So much for my mini review. Ok, I will add the output table tomorrow.Selfbuilt, I didn't see your usual chart (well usual for the last year or so) comparing the spec lumens for each mode to your estimate. I found this to be one of the most useful charts since some of the specs can be way off, and well, we probably use the lower modes on our lights the most often.
Also, the LD12 seems somewhat short on it's runtime specs, do you think it would meet its runtime on the "spec'd" 2500 mah cell (not sure it provides a full 25% bump over a 2000mah) and using a 10% output ANSI cutoff?
For the runtimes, it is true the specs seem slightly inflated, even with the higher capacity cells. It's not a huge variance. I would say the performance seen on my sample is very good - but not outstanding - for a control current circuit. Meeting those specs would certainly be a sign of excellence.
But again, you have to take this as the n=1 sample it is - average performance could be higher than this one sample.
I received mine the other day and I'm happy **yahoo** I'm not picky or an expert when it comes to lights, I've always loved Fenix, so I usually like whatever they offer, lol. I haven't noticed any flickering or problems so far, I'm totally digging it I also had and used the E11 mainly before that and I must say that the 30 lumens on the LD12 look a lot brighter than the 35 on the E11. And I'm very happy with the long run times they promise. Even if they aren't true, it must be still more than the other run times I've seen. Anyway, I'm totally digging it
........If I were to hazard a guess, there is probably some component on the LD12 circuit that is not reliably performing to expected specs, and this is generating some variable degree of interference/noise.............
Performance-wise, I am happy to report that this signal issue doesn't affect runtime - my LD12 performs as a current-controlled light should, with very good output/runtime efficiency............
This is my first Fenix light and it's a great little light. But there are a couple of things that they could improve upon.
1. It can't tail stand. This automatically knocks it out of edc rotation for me. I do use it for a backup duty light though due to it's mode memory and momentary function.
2. The modes are not spaced well. Basically the high mode, or 3rd setting, is a waste. It's indistinguishable from turbo. They should drop it entirely and add a firefly mode. Instead of 3/30/65/125 they should do .3/3/30/125. This would make much more sense from a logarithmic nature as this is what our eyes would perceive as a distinct output change.
Personally I would like to see them at least make a special run with a neutral or high cri emitter, but that can be modded if need be. I don't really care about it not having 14500 support. It has fantastic run time and I prefer to use Eneloops on single AA lights anway. I find that 125 lumens is more than enough for an edc pocket light.
