kj2 my thoughts are mostly similar. I've been using mine for a couple of weeks now.
I had read elsewhere the holster is a universal type and wasn't made for this light. I've found the same issues as you. It's of good quality though so it's found other duty for me.
Mine also has the slight green in the corona, on the lowest levels only. High is mostly all white and Turbo is bright white. I buy mostly warms, neutral, and hi cri, though this tint doesn't bother me. That's a compliment
. It's no different than any other Fenix I've ever seen.
The throw on Turbo is on par with Fenix's TK40, so I feel it's quite impressive. It feels like I have the TK40 in a more compact design, four well spaced levels, tactical clicky with momentary, a preferable battery type to me as well, and without the slow, fast, and sos blink which I didn't use.
On the issue of throttling, or stepping, down, I've run mine on Redilast and Solarforce 18650. What I've observed is that it throttles down at 3.75v from Turbo to High, however one click and Turbo is back. The torch then throttles down twice more until 3.6v where it then throttles down to medium. At this point it's time for a charge regardless. I actually appreciate this attempt to conserve my battery for me, and
I can use it to gauge my battery voltage. The override is at my command, all I have to do is click the button once and Turbo is back.
There is a lot of quality into this little torch.
