Doc Ed
Bringing back this thread because I've got a renewed interest in this light. My current primary light is a modified bicycle light, and I was thinking of converting this "proper" dive light into a sturdier version that what I'm currently using.
As mentioned previously, the construction of the light itself is rather good. Here's a side-by-side with my current back-up, a Trustfire TR-J1:
The battery tube and switch assembly of the light can be easily removed from the head. At the tail cap are some square cut threads, and both ends are protected by double O-rings.
The "light engine" as mentioned by Arek98 seems to feature 3 7135 chips (not too sure on this though), giving about almost 1A of current at the tailcap (single 18650 around 4.01v only though)
The magnetic switch can be disconnected from the rest of the battery tube. This is what I intend to do when I convert the head to an XML for can-light purposes:
The head itself is pretty robust. There are several O rings on the front part alone: In front of the lens, behind the lens, around the edge of the reflector, the base of the bezel, and even around the base of the emitter.
Considering its diameter, I think the lens is more than adequate to do its job
So here's my question now: I purchased some proper Agro cable glands courtesy of 350xfire, and some proper cable as well. Likewise ordered a latching hallswitch made by Taskled. I was thinking of enlarging the space in the "light engine" and slipping in the switch over there so the original magnet can still actuate the light. Also got some 8x7135 drivers to drive the XML I have to almost 3A. Considering the dimensions of all of the above, and with the caveat that this light will definitely be only for underwater use, do I have to worry about overheating the components with these specs?
