i think an ROP is the way to go as everyone seems to recomend it
The ROP is such an easy mod that everyone should do it. Nowadays you can get all you need "off the shelf". Back in the days you had to fabricate you own battery holders, assemble the battery packs from whatever cells you could scrounge up, cut the stock reflectors and so forth. Now you can get 6xAA battery holders from
FiveMega and
SandwichShoppe (though out of stock), the Pelican 3854 bulbs from
Lighthound and an aluminum textured reflector from
BriteLumens and
KaiDomain. I use the textured reflector for the smooth beam it provides. The ROP is definitely my "WOW Light".
i think i am going to go with the ROP because i want more power than i already have and it would be my only incan ! ...But the micropuck does look like a good no hassle cheaper option that wouold also give me a good light, but i still think ROP
what battery setup is best for an ROP and how many volts do i need
jamie
Check out this
thread for the various voltages for the ROP. I use 6xAA Eneloops/Duraloops for mine in a 2D. You'll also see the predicted lumens. My ROP Hi is easily 900+ lumens at on fresh charged cells settling into the 600's. As far as runtime, I can get ~30 minutes of diminishing light from 900+ to ~600 lumens with the ROP Hi. A bit over an hour with ROP Lo with roughly half the output. If you have a 6D and
12000mAh NiMH cells you could get 3 hrs of runtime!
...and have a nice club to boot.
