Hope this is the right subforum. I have some generic questions about LEDs in general. Here they are in no particular order:
1. How much of the input power to an LED is lost as heat? For example, take a Cree XM-L running with 10W input power (3.2V x 3.0A). How many watts are actually dissipated in the heatsink?
2. For multi-LED setups, is the total number of lumens simply equal to the sum of the lumen output of each LED (eg. 4*1000lm LEDs = 4000lm total)?
3. If you needed, say, 500 lumens for a project, would it be best to use a single LED running at 500lm, or multiple LEDs running at less lumens (say, 2*250lm or 5*100lm LEDs) - assuming the LEDs used are running at less than their maximum lumen rating? (so for this example, say the LEDs available are all capable of 1000lm but running at reduced current).
4. What is the current "best" high-power (over 1000lm) single LED on the market? Is it the Cree XM-L2 or are there other LEDs with more lumens per watt or more lumens per dollar?
5. What is the single most powerful single LED currently on the market (in terms of lumens)?
