The work light
This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
-Up to $100.
3) Format:
-I want a flashlight (hand held/self contained).
4) Size:
-SMALL - Every day carry (4-7 inches).
-*MEDIUM - Holster/belt ring carry. (>7 inches)
--*The smaller size is greatly preferred, but I am curious as to what medium sized options are out there.
5) Emitter/Light source:
-LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
-I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
-**I would like a light from a specialty manufacturer (Possibly limited run/Custom).
--**Similar to the size category, I'd prefer the first option, but I am still curious as to the other options.
-I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
-I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
-I want a light with an integrated rechargeable battery pack.
--I have this listed in order of preference. I'm planing on using rechargeable 18650's. On that note, any opinions on 18650's with built in USB charging ports?
-I want a light that has a recharging adapter (your typical "wall wart")
-I want a light that snaps into a cradle (usually mounted on a wall)
-I want a separate/stand-alone charger (this involves removing the batteries to charge)
-I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
-I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
-I want search and rescue type illumination (800+ lumens).
--I would prefer a milti-mode light that can handle all this these categories.
-Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
-Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
--Either of these will work for me
-Less than 1 yard/meter (reading, other close work)
-Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
-5-20 yards/meters (check out a noise in the backyard)
-30-50 yards/meters (I have a big backyard)
-50-150 yards/meters
-90-120 minutes (Runtime is moderately important, but still not critical)
-Critical (Police, Fire, Search & Rescue, Caving, Survival).
--I will be primarily using this light while doing night club security.
-I want a tail mounted switch (found on the majority of today's high end lights).
-I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
-I want multiple light levels. (Some lights have 5-16 light levels.)
-I want a programmable light.
14)Material/Finish/Coating
-Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
15) Water resistance
-IPX7 (Waterproof to 1 meter/30min)
16) Storage conditions
-Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
-Pocket/belt clip
-Crenelated bezel
Hello world! I'm looking to get a new flashlight. I'll primarily be using this light while working security at a nightclub. After looking around some, I'm thinking about the Nitecore P10GT and the Fenix UC35. The main differences between these two are as follows:
Nitecore P10GT
-The strobe function being a separate switch and not needing to cycle to it.
-Simple, two brightness mode as a user programmable option.
Fenix UC35
-Built in USB recharging on the flashlight.
-A higher max brightness than the P10GT (820 on the P10GT vs 960 on the UC35)
What I would like the most is a P10GT that also had built in USB recharging. I see the MH lights on the Nitecore website, but they closer to the UC35 than they are to the P10GT in terms of operation.
Thanks for the help!
-Up to $100.
3) Format:
4) Size:
6) Manufacturer:
-Pocket/belt clip
-Crenelated bezel
Nitecore P10GT
Fenix UC35
