Sold/Expired Forky SS bezel for MiniMag
download
Sol 3
A limited no. of Aggressive & Plain SS Incan MiniMag Bezel added.
It is direct replacement of Incan MiniMag bezel. :party:
jcvjcvjcvjcv
The Netherlands
So there is the pacifist and agressive bezel, both in the Incan (short) and LED (long) flavor?
What is the diameter of the Cree reflector?
So an Incan Minimag with a large LED (I'm actually planning a P7 minimag) with that Cree reflector would require the larger LED bezel, right?
download
Sol 3
For MiniMagLED: pacifist and agressive SS bezel
For Incan MiniMag: Stock like and agressive SS bezel
Diameter of the Cree reflector is 21mm. Use with MiniMagLED bezel to Incan MiniMag head only.
I think P7 emitter size is a little bit too large for 21mm size reflector.
Cree MC-E will be more comfortable to 21mm cree reflector.
Like Cree MC-E drive with 14500 x2. Use FluPIC & wire like this:
Sing
:paypal: For
Aggressive SS Incan MiniMag Bezel $26
Shipping to Worldwide $4
Registered mail (with Tracking) $3
sunspot
Graham, NC
Aggressive SS Incan MiniMag Bezel $26, 1 each
Brass heatsink for Incan MiniMag $9, 1 each
$4 shipping to Worldwide
Cash Paypal:
Total: $39 :paypal:
collector
NICE ! Which version did you buy ? The LED or INCAN version ?
@download: Which is smaller/shorter ? I think the LED-version is shorter ?
:takeit:
I'll take 1 "Aggressive SS MiniMagLED Bezel"
I'll let you know which.... Thanks !
Mine came today!:naughty:
Thank you!
Now I have an L4/P7 Porcupine..:cool:
I still have to get a small spacer or o-ring to fill
the gap between the domed window and the bezel.
download
Sol 3
collector,
DaFABRICATA is using LED version.
The Fork length is same of both, just the back of the thread is different.
LED version of thread is longer, Incan version of thread is shorter.
If you have stock MiniMag Incan & LED in hand, you will see the bezel is different thread length.
This Forky bezel use same thread length of both.
collector
So given DaFABRICATA is using the longer LED version, he needs a spacer for a tighter fit on the lens. I would also use this on my KL4, so I think the INCAN version would sit better on the KL4.
Last question, how much shorter are the threads compared to eachother ?
Thanks !!
download
Sol 3
They are direct replacment. That mean they are same internal size of stock bezel.
I would suggest you test your minimag stock bezel in your light first.
You will get same result of the Forky bezel. :)
