discoverEDC
That's 4K? Wow.
Camera balance I bet. Take the same picture and add a 3000k light in the mix and that one would probably appear orange.
That's 4K? Wow.
anyone know where to Source like a quality 4300k LED for these ?
also considering hcri 4500k. trying to get close to 4300. maybe 4500 can be a 4300?.
thanks.
I haven't dealt with the emitters that Fraz uses, I've been using XPL HI, but color binning has gotten a lot tighter so if you order 4500k you will get pretty close to that. Fraz mentions earlier in this thread some sources. It's a ways back I think. 4000k and 5000k are pretty common but I don't know about in between.
Mountain Electronics is a great site used by the flashlight modding community. Note that the forward voltage of the XPL-Hi is a bit higher than the LEDs typically used by Fraz.
Sent from my iPhone using Tapatalk
I'm curious about output and beam pattern with the different LEDs. Does anyone have, or can produce comparative beam shots?
thanks.
Could someone break down the general characteristics of the three models? I gather they go Tiny Nugget-->Tiny Tank-->Lumenite in terms of size, and that the Tiny Tank is "more of a flood pattern", but that's all I could pick up from the Fraz Labs site. Do the three models use different optics? Is there a comparison of the beam patterns anywhere? Anything else I need to know before ordering?
The Tiny Tank is a stouter version of the Tiny Nugget. The wall thickness of the head is thicker. The two Tiny lights can be ordered with 18350, 18500, and 18650 body tubes. I believe that the Lumenite comes with a 21700 body tube and is bigger in general. This also allows for a larger diameter optic. All three use the same types of emitters. I haven't read it anywhere but I'm guessing that the Tinys use 26mm diameter optics based on the size of the lights and standard optics sizes. All this said by a guy who hasn't even held one in his hands Others can verify but I'm mostly certain that I have it right.
Hi all! First time poster, brought here by a reddit post in r/flashlight. I look forward to discussions with fellow addicts!
I am posting here mainly to express my interest to Paul or Felicia in pretty much any 18650 or 18350 version of any of the lights, preferably in a higher CRI LED and preferably in a warmer temp (below 5000K) but, really, probably anything will do. I've expressed interest on the website to one of the configs, but I didn't want to spam the site with interest in every one of them. I know I'm both at the bottom of the list and the totem pole, but I'm fine with that. I'll be looking for any notifications here, and, barring those, I'll be checking the site frequently. I think it's wonderful when new(ish) makers break into the scene and I want to support that. Also, these lights are very different, in a good way, and I enjoy how they are not "typical" lights.
Also, I wanted to say that I read through the introductory posts at the beginning of this thread and found them to be incredibly interesting.
Nobody is at the bottom of the totem pole here in the land of Fraz. If flashlights are available and you have legal tender to send them, go ahead on with your totcczar self.
Beam pattern comparison: M61 (reflector) | M91T (optic) | Lumenite 21700 (optic):
WB/exposure auto locked on the M91T. Lumenite has an excellent balance of spill and throw, approximately right in between the M61 and M91T.
