fulee9999
- Joined
- Mar 3, 2021
- Messages
- 717
technically you can put any conductive material between the pcb and the clamps to achieve this, but yes, as ninja said a small blob of solder works best
I'm not seeing any of the low moonlight levels
have weird corona around the beam
Gee I'm not having much luck with mine. I have an unprotected 18350 at 1.35inch's/34mm long and it's almost too short - I'm not seeing any of the low moonlight levels (my regular Emisar D4V2 is miles lower) it just jumps to a much higher mode, have tried 2 pieces of QTC. I ordered a slightly longer protected battery which I thought would help, it arrived but is 1mm too long and doesn't engage at all. I'm going to have to order the one in this thread from Illumen, shipped to Australia is about $40AUD. Don't know if it's a battery issue or what.
Also have weird corona around the beam, see photo's where it's on top then i rotate the light so you can see it's at the bottom. Have reseated the optic but no differece. Have ordered some frosted optics so hope they help. Any ideas?
PS - not complaining, have spoken to Fraz Labs and they are very helpful, just wouldn't mind checking with the hive mind as well
So is the square in the middle or on the right which one?😁
I don't know if you can on the QT Gold - the bottom is 1 solid pieceYou can unscrew the tailcap for longer batteries...use split ring pliers.
