[ QUOTE ]
batterystation said:
Hey guys-If you have a charger that discharges the batteries to aprox. 1v per cell, that is great UNLESS you are using metal hydrides. They hate this process. They have no memory effect to speak of and therefor hate being ran down that low. If that discharge feature is manually controlled, don't do it to the NiMH cells.
[/ QUOTE ]
While the need to discharge NiMH cells the way you would NiCD is overcome, the belief that damage occurs to the NiMH cells when discharged to just under 1.0 volt is a misinterpretation of NiMH recommendations. NiMH and NiCD alike shouldn't be discharged too deeply in a battery pack or collection of cells in series simply because one of the cells will drop low enough to receive a reversed polarity charge from the other cells. It's the reverse charging from neighboring cells that can damage it.
One volt per cell in a series is safe for NiMH. Unless the cell is already damaged beyond reason a one volt cell in a series isn't low enough to be receive a reverse charge from the others. A cell that different from the others in the series, or in a pack is useless and needs discarded anyway.
In a single cell charger, or a parallel charger such as the C. Crane unit, a cell could safely be discharged to near zero without damage. I wouldn't recommend taking any kind of chemical cell, whether NiMH, NiCD, alkaline or carbon zink to absolute zero.
NiMH was developed to remove the limited use problems resulting from the NiCD's so called "memory" effect. If you limit a NiMH deliberately to avoid "damage" from discharging you've invalidated the advantage of NiMH.
Let your NiMH flex it's muscle and exercise. It'll live longer. Frequent charging is worse than reasonably full use.
