OK quick question...
I have a $5 smart charger that automatically chooses the voltage, and charges about a little under 200 mAh I hear... Its supposedly rated at 380, but it appears to take longer than 2 hours to charge a 14500. Furthermore, it won't charge past 4.17 volts. It'll stop, wait for the battery to drop below 4.17, then charge it back to 4.17. Left if for hours on end and it won't get any higher.
Is this a "safe" charger for unprotected 14500s?
[BTW sku.14885]
automatic is never "safe"
but then again neither is some peoples manuel
from the specs you presented this is (about) how you would want it to work, just you should not leave it on the charger anyways, that is just asking for some high tech piece of junk to bite you.
also manually check your cells for self discharge (especially the 14500s) to insure that they are still alive, most do not last good time, although at the RATE of charge it is unlikly to cause any ignition, still a user knowing that the battery still works before jamming it into any charger is some of the safest things you can do.
AND
NEVER use this auto junk on an SERIES set, specially with Un-protected, you always want
balancing or singular channel charging or finishing at least. you CAN "get away with" series charging with protected cells, but not at all with unprotected.
Protected cells will just not be all charged the same,
unprotected the charge differential has no singular cutoff,
so although the TEAM could be within the (say) 8.4V for 2,
3.8V+4.6V still equals 8.4v and i think you can see the problem with that.
