How long is 50,000 hours?
There are 8,760 hours in a year, so here's what 50,000 hours works out to be, depending on lamp hours of operation.
Hours of Operation:
24 hours a day 5.7 years
18 hours per day 7.6 years
12 hours per day 11.4 years
8 hours per day 17.1 years
Why is the life span of an LED measured as lumen depreciation?
The life span of an LED is vastly longer than that of incandescent, fluorescent or HID lamp sources, generally lasting 50,000 hours or longer. Although the LED never really burns out, product life span is measured by lumen depreciation.
The Illuminating Engineering Society's (IES) current standard for calculating the life of an LED as the point at which the LED reaches 30 percent lumen depreciation.
Remember, a 100,000-hour rating is not equivalent to lamp life rating. LED life is rated where it has reached 30 percent lumen depreciation. At 100,000 hours an LED would still be operating, but at a decreased lumen output.
What is junction temperature?
Junction temperature is the temperature at the point where an individual diode connects to its base. Maintaining a low junction temperature increases output and slows LED lumen depreciation. Maintaining a low junction temperature is critical for evaluating an LED product's quality and ability to deliver long life.
What can affect the LED junction temperature?
There are three things which can affect the junction temperature of LED's: drive current, thermal path and ambient temperature. In general, the higher the drive current, the greater the heat generated at the junction. Heat must be moved away from the junction in order to maintain expected light output, lifespan and color. The amount of heat that can be removed depends upon the ambient temperature and the design of the thermal path from the junction to the surroundings. Typically the junction temperature should be maintained below 120°C.
Hours of Operation:
