JWP_EE
I bought it in DEC 2007 but it was out before then. I am running it at 600ma. At that current the curve says 60 lm/W, so the output is about 120lm.
Are electrolytic capacitors used in most of these regulated led lights?
They seem to be rated up to about 2000 hours of life. As they age their ESR goes up too.
Some of the older hands here might recall reports of the LuxV exhibiting a visible decrease in brightness after as little as 500 hours of use. Apparently those were driven hard enough to get HOT in some lights.
Edit: And if anyone expects 50,000 hours of runtime from LEDs at 'CPF' drive levels, I have a 500,000 hours MTBF (i.e. 57 years) hard drive to sell them.
I have some LEDs on a fan controller in a computer I built
The LED dimming behavior most often observed here is that our current lights suddenly get dimmer when the 'new one' arrives in the mail, lol.
+1 I have a box of dead l4s somewhere as well as some working ones. But those l4s get almost hot enough to burn you after a few minutes. Great flood beam but the output is soo dated now. It's interesting to see how far we've progressed. I also have an old Felix that's been used every night since I bought it. Don't know how old it is but I have it hanging over the bed and use it as a night light on low and bump it up to medium for reading. I use it to fully drain my primaries taken from my work lights. I'll have to find and pull out an unused Felix from the same batch to compare brightness but I don't think it's necessary cause the turbo output is still comparable to my newer lights. Probably cause it hasn't seen much time on high or turbo. On the other hand I did have an original zebralight cr123 the very first model they put an electronic switch into that was nearly at half brightness on high when I gave it to a police officer a few years ago. I had it clipped to my work shirt pocket and surprisingly he thought it was one of the smallest brightest lights he had ever seen. It was a good excuse to start using a newer aa zebralight. That zebralight saw heavy use on high and got pretty warm at times. So probably just outlived its useful lifeExample from real life: SureFire L4 (KX4 bezel, IIRC).
Power or 5mm?
I've been pondering over this for some time now; that if you take into account the longevity of non-power LEDs, you're going to find several examples in every household that have been on for a very long time. Consider the LEDs on your surge protector that have been on nonstop since you plugged it in, or the indicators on your cordless phones, or your television equipment, your computer equipment, etc. Even a cursory glance around your house will turn up a number of indicator LEDs that have many thousands of hours of runtime on them..
I don't think any of my surge protector indicators have dimmed. Some of those are nearing 15 years or older. Ha ha! I think it may be time to upgrade those.
I have ran an SC60w now for 31,000 Hours! Most of them have been on L1 or L2, but I have had at lest a 1,000 hours on H1 or H2. It has been our "Pool light" the last 3 years, and edc'd every day. It's on it's third O-ring.
I can't tell any difference in brightness from new ones ( I have 3 others).
