I've got a Topeak Moonshine HID bike light that uses thw WA 10w HID & ballast does anyone know where I can get a replacement PCB board for it or is it possible to replace it with the Trailtech PCB (as the lamps use the same parts)
"unfortunately" it is so simple, nearly noone I have told yet, believes it.what causes the HID to strike its initial arc? is it in the control circuit or in the lamp?
"unfortunately" it is so simple, nearly anyone I have told yet, believes it.
There is the driver that steps-up the battery voltage to the roughly 65 V the HID bulb needs and - mounted parallel - a Voltage Multipier (Greinacher or Villard cascade)
As long as the arc does not work, the power goes to the Greinacher, till the voltage is high enough that there is a strike.
Again the arc does not start - the next spark form the Greinacher
every time there is a strike, the gap between the contacts "looses resistance" and at some time the arc stands,
more and more power goes to the normal step-up and the HID "goes off"
better call it the "ballast",all these are happening in the "igniter"
The Trailtech bike HIDs are similar with a small control circuit board that contains battery level LEDs & a switch - is this just that or does it have anything to do with striking the arc in the lamp?
Thanks for that, I found on another forum that there is an upgrade using the WA NGX series of ballasts that contain the voltage reg circuit so have a much wider input range & are also more efficient.
http://www.walamp.com/lpd/webstore/detail.tpl?partnumber=B10R001
http://www.walamp.com/lpd/webstore/detail.tpl?partnumber=M10P003
I'm looking to do a group buy to the UK of these lamp/ballasts to share the shipping charges.
nice prices in those links.
Has the bulb been updated in output? Because I never liked the 10 W HID and now - with MC-E and P7 - dont think it makes any sense to go the way more expensive 10 W HID route.
Posted yours today Steve.
These NGX's don't half chuck out some light compared to the older Solarcs!
