Small progress made on reflector mouting.
Cut Mad D head into 3 sections:
Two of the sections will be used to sandwich the reflector with the Mag tube being the mounting axis:
One of the mag cut piece was further grind down & is used to connect reflector to lamp mounting rig. Spring loaded Triple screw XYZ adjustment type. This rig came out of a mercury short-arc lamp house, in which it was used to mount a tiny reflector behind the lamp.
The other mag head cut piece is used as a lock ring to lock down the bottom plate using mag tube threaded neck section, so the lamp mounting rig is locked in place.
I think I am almost half way there. Just need to figure out a way to mount the lamp to the bottom plate & present the arc chamber inside the reflector at the right height.
