from what i saw it uses this kinda setup
|{=====]{=====]{=====]{=====]| ~4.8v on ni-mh
|{=====]{=====]{=====]{=====]| x2
that is why it still runs when you
|...............................................| x0
Notes: although it will run with a single set, the load on the batteries would be nicer with both sets.
BUT
If you do not have Matched sets, in , age, type, quality, brand, capacity, internal resistance etc, you might be better running it with only 4 batts in it, till you do. run it at a lower power or something.
any single item in it, turned the wrong way, and still fully connected gives you this
{=====]{=====][=====}{=====]| ~2.4v , 1 reverse charge cell, and ~2.4v differential causing a huge 3 cell cross charging too.
mabey this explains the 3 easier, they might have been being overcharged, while the poor single is being destroyed from reverse charge? then of course adjust the numbers and the current with different types of batteries, alkalines causing you least heating, and lithium causing the most heating and most dangerous situation in general.
as to marking stuff better , here! here! some devices and thier slightly raised markers for polarity need a big Fat black arrow on white. just so it takes less time to figure out.
i am happy someone posted this,
even if you blow the light up completly :mecry: it is GREAT to get user experience leading to more info about the light and how it works, so people using it can understand, and take great care in using only fully matched sets of batteries in it.
it is a great light and a great design, if everyone knows how to Feed the sucker.
as Led Museum would say " It's Feeding Time "
as mentioned the Parelleling of the 2 Series sets is done in the Holder itself, so it is when you put it in the holder , reguardless of the flashlight , that any issues would already exist, also a light under that condition might actually RUN, so it operating does not define that the batteries are set correct or matched. that work has to be done by the user when installing into the pack.
and to further clarify, this is not a Spare battery carrier
you should NEVER mix , for example lithiums and ni-mh or lithiums and alkaline, or any other mix, YES including kirklands and duracell, or anything else you can think up.
{=====]{=====]{=====]{=====]| ~6.0v on lithium
as you can see another large voltage differential that is sure to drain the lithium, while overcharging the ni-mh giving you very poor life of both :sick2:
8 batteries the same, not so hard, they sell them in 12 packs
