The most important reason to not charge at high rate is the risk of
Many battery datasheets do list a standard/recommended charge rate and a fast charge rate, the short form Panasonic data sheets does only list one charge rate and calls it maximum. This might be correct or not. My guess is not, but I will not recommend using much higher charge rate without a datasheet saying it is allowed.
I agree that excessively high charge rates may cause catastrophic failure in batteries. But most people would not consider 1C a high rate for lithium's. I know you had run-ins with the RC crowd before.
But it is not uncommon for them to charge at 5C and above. The RC crowd is light years (pun intended) ahead of the flashlight crowd when it comes to batteries. Just a lot more user data to go off of, as well as a larger community pool for data.
I do like hobby chargers and often use them, but for daily use a fixed rate cradle charge is much easier.
I agree with this statement but this has nothing to do with what I said.
Not to mention that when you have your routine all set up and worked out it is not that much more difficult to utilize a hobby charger.
I also think that fixed rate cradle chargers have their place. I was actually going to PM for a recommendation.
I had a cheap hobby charger at it lasted a long time, but then the background light for the LCD quit.
My general opinion is that a $30 hobby charger is better than no hobby charger, it might not be precise, but you can still get a good estimate of battery capacity.
It's a $30 hobby charger for YOU. Remember you have a ton of gear. Others will need to get a power supply, leads, magnets (by the way those that do not know how to solder they are already selling charge leads with magnets attached to them), as well as pigtails for balancing. Right there you have 50+ dollars.
