7.5.1.3 Cylindrical cells dimensionally interchangeable with primary cells
The cell shall be tested in accordance with 7.5.1.2. The total number of cycles obtained when
the test is completed shall be not less than:
• 500 for AAA cells with a rated capacity less than 800 mAh;
• 300 for AAA cells with a rated capacity of 800 mAh or more;
• 500 for AA cells with a rated capacity less than 2100 mAh;
• 300 for AA cells with a rated capacity of 2100 mAh or more;
• 500 for D and C cells.
http://www.ptl-global.com/Upload/036BSEN6195122011-16203028481.pdf
eneloop rechargeable batteries represent renewable energy
and can be charged up to 1,800*1 times! Using eneloop rechargeable
batteries will help in the reduction of disposable waste and thus benefit
the environment. Let's keep batteries out of our landfill.
* 1: A guideline for battery life based on IEC61951-2 : 2003(7.4.1.1)
eneloop:
Rechargeable up to 1,800 times.
A guide-line for battery life based on IEC61951-2:2003(7.4.1.1)
*5 Battery life is based on IEC61951-2(7.4.1.1)
Recharge *2 up to 2100 times
Note *2 indicates the following: "Panasonic internal testing IEC61951-2 (7.5.1.3)"Cycle life *2
I just checked and added the question to the FAQ.
Love your devotion
But after a long internet search I just found another site with the original 2003 release from IEC. Thanks a lot.. Downloaded it for reference, thanks a lot!
As you can see the 2003 and 2011 IEC editions are completely identical for the cycle/endurance test. I compared them both, 2003:7.4.1.1 and 2011:7.5.1.2 and can`t find a difference either. The way I asked the employee is: I see that the coding (which I didnt check...my mistake) for testing has changed, would this mean that the testing has changed? And the employee answered: we have tested 10 years old cells to come to this conclusion...so my wrong interpretation was that they changed the Measurement... which I now learned are not. Also the employee didnt refer to any specific JIS pages or anything.. It was just my wrong assumption because of the different codes and the answer of the employee. I will correct that on my website.Thanks a lot for clearing this up!!! that really adds value to my research so much!!
While searching for the old IEC version I also found two old Sanyo Eneloop guide books for 1. and 2. generation eneloop.
It states that also the old tests (7.4.1.1 (2007)) was indeed IEC standards (see page 4 and 11 on the links below the quotes). Now you have documentation for how the old test was done too if you are interested. Yep, that is great. I had the latter one. The only thing that draws my attention is that it refers to the 61951-2 instead of 61951-1.. I assume they are the same thing..
No thank you, only if you find discrepancy between the two versions. Nope, but I found that the 2011 IEC version you linked to is a little more detailed while talking about the Charging procedure, saying within a relative humidity of 65% plusminus 20%. 2011:7.2 and 2003:7.1
After the quotes from the old Sanyo Eneloop guide book above, I think that also the old JIS version was Identical to IEC, although I haven't checked that edition. But everything indicates it.
Yep.. seems to be the case!
Yes exactly
It looks great. Thank you for all the information and hard work.
The only thing is, the gray text is a little hard to read for aging eyes. Any chance you can just make it plain black?
Great stuff. Now I am getting a little used to your messages because after reading and comparing the PDF files I can finally follow you
Be aware that IEC61951-2 (7.5.1.2 ) and IEC61951-2 (7.5.1.3) is the exact same thing, since paragraph (7.5.1.3) doesn't actually have a test of its own, but simply states the test must take place under the conditions mentioned in paragraph 7.5.1.2. That was the main reason I previously recommended also to read paragraph 7.5.1.3.
Yep, I followed that!
And below, quotes from a panasonic catalog also for generation 3 taken from first and last page. (The catalog is taken from your website by the way)
Unfortunately this PDF doesn't allow me to copy/paste. But in first section on page 1 is written "the new eneloop batteries are also rechargeable approximately 1,800 times *2" On the last page (note *2) indicates: "General estimate based on the IEC 61951-2(7.4.1.1) testing conditions (the number of times a battery can be recharged changes according to the use conditions and equipment used)"
Yep, I got that!
Another interesting part I found from the latter PDF was a reference to IEC61951-2(7.3.2), which I suspect is identical to JIS C8708 2013 (7.3.2) the one a EU Panasonic employee had referred to you said.(That was my misinterpretation.. see my previous reply)That test however is about capacity/discharge.
So now we have clear documentation that both generation 1,2,3 and 4 from both panasonic and Sanyo are testet under respectively IEC 61951-2:2003(7.4.1.1) and IEC61951-2:2011 (7.5.1.2/7.5.1.3) for the cycle test. That also tell us that JIS 8708 2007 and JIS 8708 2013 are identical to the IEC versions above regarding the cycle test I would say.
I agree, and thank you SO much for helping out.. It helped me tremendously. Now I can read your posts without getting a headache
The more terminology the more confusing sometimes. Well, the MIT doc is just another way of explaining what the 70% would mean. Just in different wording (terminology). So charge and capacity are sometimes used interchangeably so that might be a bit confusing. I hope to not confuse too many people on my website:twothumbs
the new FAQ item is excellent!! Very helpful and clear and eindeutig. Thanks for having added it, appreciated.
( i didn't understand the mit.edu explanation of SOC, too confusing, yeah we don't need that thx )
ChibiM;5099434 [COLOR=#333333 said:While searching for the old IEC version I also found two old Sanyo Eneloop guide books for 1. and 2. generation eneloop. [/COLOR]
I didnt notice the one was for nicd. Also I just came across the 2017 which is probably impossible to get without buying the actual PDF file.
They look pretty much the same to me.
7.4 Endurance
7.4.1 Endurance in cycles
Prior to the endurance in cycles test, the cell shall be discharged at a constant
current of 0,2 It A to a final voltage of 1,0 V.
The following endurance test shall then be carried out, irrespective of cell designation, in an
ambient temperature of 20 °C ± 5 °C. Charge and discharge shall be carried out at constant
current throughout, in accordance with the conditions specified in Tables 9,10, 11 and 12.
Precautions shall be taken to prevent the cell-case temperature from rising above 35 °C
during the test, by providing a forced air draught if necessary.
NOTE The actual cell temperature, not the ambient temperature, determines cell performance.
a If the cell voltage drops below 1,0 V, discharge may be discontinued.
b It is permissible to allow sufficient open-circuit rest time after the completion of discharge at cycle 50, so as to
start cycle 51 at a convenient time. A similar procedure may be adopted at cycles 100, 150, 200, 250, 300,
350, 400 and 450.
Cycles 1 to 50 shall be repeated until the discharge duration on any 50th cycle becomes less
than 3 h. At this stage, a repeat capacity measurement as specified for cycle 50 shall be
carried out.
The endurance test is considered complete when two such successive capacity cycles give a
discharge duration of less than 3 h. The total number of cycles obtained when the test is
• 500 for L/LR, M/MR, H/HR or X/XR cells;
• 50 for LT, MT or HT cells;
• 500 for button cell
I hope you have better luck finding it than I had. I have spent about an hour or so surfing the net for the graph or a similar one.
Actually I initially thought I could help you, because I had bookmarked the site with that graph, and haved linked to it a couple of times on CPF. unfortunately, the site seems to be gone now. It was this link below, if it was the same site you remembered having seen.
http://csknowledge.panasonic.co.jp/app/answers/detail/a_id/18109/~/%E5%85%85%E9%9B%BB%E6%B1%A0%E3%81%AE%E3%80%8C%E3%81%8F%E3%82%8A%E8%BF%94%E3%81%97%E4%BD%BF%E3%81%88%E3%82%8B%E5%9B%9E%E6%95%B0%E3%80%8D%E3%81%A8%E3%81%AF%EF%BC%9F-pz18109
