jimbo231
Do I need to remove spring on drop in to wrap with tinfoil and use in solarforce l2p or l2m or do I use with the spring on?
It depends on the brand of pop. If it is Coke, especially Coke Zero, you might have some problems. However, if it is Pepsi, you'll be good to go.I used a strip of pop can but kept the label on the one side. Is that ok? The heat should still transfer...no?
It was coke zero.......what are the odds. Oh well I'll try again with a different can. :sick2:It depends on the brand of pop. If it is Coke, especially Coke Zero, you might have some problems. However, if it is Pepsi, you'll be good to go.
Also, from what I understand, if you use a beer can instead of a pop can, it seems to work better.
