:welcome: Brian
You'll notice in the first post I cleaned both sides of the aluminum with steel wool, leaving just bare aluminum as seen in the photos.
Norm
thanks. ive been lurking for about a month or so. made an intro post the other day and got sucked in already lol.
yeah i saw your pics.
years ago in college i experimented with that aluminum brazing rod stuff and they recommended using stainless steel brushes to get the aluminum oxide off of the metal and acetone to get off other impurities. im just applying that stuff here to flashlights.
I tried the soda can solution then the wrapped aluminum foil. Can method nice but takes a bit of final trimming. Foil can get that tight perfect fit but slides a bit as I seat the pill. Yesterday I tried the adhesive aluminum tape. Got to say I much perfer the tape method it stays exactly where I put it.
i like the aluminum can method because there are less layers. every layer adds a little bit of inefficiency.
i took my digital caliper and measured around a .0365" difference between the inside diameter of my flashlights and the p60 drop in. i got a piece of .040 aluminum and sanded it to ~.036" and then wrapped the drop-in and tried to insert it. wouldnt fit. i assume it was because there were bumps and such in the aluminum from bending it around the module, sanding and working with the piece and to get a good fit, id have to press the parts together with a bit of heatsink paste on the spacer, the module and the light itself.
since i like to swap parts between all my lights, i wasnt willing to press fit my stuff together for the ultimate in heat conduction.
i find that the aluminum can method is the next best thing. i have to give it a pretty good twist/push to get the module into the light.
i do have to trim the aluminum so that the beginning of the can metal and the end of the can metal dont overlap so that that the in-between-layers have room to flex as each layer transitions to the next layer so that the maximum amount of aluminum sheeting is contacting the next layer.
either way, anything is better than not adding metal to try to pull the heat from the module to the body.
Brian
