I want to add a few notes on batteries and runtimes to this thread as it pertains to this mod.....
I decided to get brave reciently and try a rechargable lithium battery in my light. As some of you may know this can be dangerous because the full charge voltage of these batteries is somewhat higher than the standard non-rechargable types. The risk is that you fry the electronics...not really a cheap option in the case of an X2L.
Can it be done? yes...and no.
The light will not explode with the rechargable battery. My light is surviving just fine.....HOWEVER The LED gets too hot too fast. My runtime before thermal shutdown is about 5 minutes. The big bummer is that now that I have been using the rechargable battery, going back to the non-rechargable results in almost no light what-so -ever??? Some sort of dammage has been done to the LED circut, but I don't know what....It still works great with the rechargable battery, so I am going to just stick to that untill I decide to replace the terralux LED. The laser is unaffected and continues to work the same either way.
Technical Data: I am using a charger that has two voltage settings, I am using the lower setting which stops charging the battery at 3.8 volts. The high setting charges to 4.1 volts and that would definetly fry things. Just for reference, non-rechargable lithium battery voltage is ~3.25v fresh from the box, but drops to 3.0 the second you put a load on it. The Terralux LED will give tactical light down to about 2.4 volts, at 2.0 it becomes useless. The laser continues to function well below 2 volts.
I also had a chance to do this mod for someone else, which gave me the oppurtunity to compare light output of a new LED with a standard battery VS mine with the rechargable battery. NO DIFFERENCE!!! I was shocked....I guess the regulator circut of the LED is good at it's job.
Runtime with the Terralux LED and laser on the standard lithium battery is 45 minutes at max output plus an additional 30 minutes of usable bright light, then another 20 minutes where the output diminishes quickly. I tersted this by running my X2L in 1/2 hour spurts with 15 minute breaks to let it cool. I have never had a thermal shut down with a standard battery.
Bottom Line: Hell of a trade off...Don't go rechargable unless you can deal with a light that only works for 5 minutes before it quits.
