goldserve, I figure I'll ask this here since this thread is what your posts usually refer to when someone asks about the specs of the FLuPIC. What are the electrical specifications of your FLuPIC? Either I've completely missed a post that listed all of it, or maybe I'm going blind. Anyway, I've had to scrounge through several threads to piece together what I think are the proper specs. Please correct me if I'm wrong and I'll edit my post with the correct info.
Max Input Voltage: 5.5V
Min Input Voltage for regulation: LED's Vf + 0.15V
Drive Levels:
Burst Mode: 1.2 A
Level 20: 500 mA (some posts refer to lvl 20 as 600 mA, so I'm not sure which is correct)
Level 19: 475 mA (one post said that the level increments are 5%, which I assume means 5% of max current, which is 25 mA)
Level 18: 450 mA
Level 01: 20 mA (another post specifically stated lvl 1 as 20 mA)
It also looks like this circuit is almost custom tailored to under-drive TxxH bin LuxIIIs (except for Burst mode). Would it also be suitable to drive say a... SxxH bin LuxI as long as you don't go above lvl 14 (350 mA) in normal extended use? My assumption is that a SxxH-bin LuxI driven at spec (350 mA) would be whiter, brighter and run longer than a TxxH-bin LuxIII driven at the same current (at 350 mA, where the LuxIII might color shift to some undesirable tint).
