May I ?
You can have all 5UIs on the board
and switch to them whenever you want. (read on).
Given you have a clicky-switch (click on, clock off)
and given you have the light on UI1 now.
Your light is [off] and you click it [on] once;
Light turns [on] on [Level1]
Click again (to off), light will turn off and "reset".
Next time you turn it on, same story.
Now, if you click twice, like [on]-[off]-[on]
and the [on]-clicks being no more then 1 sec apart,
the light will be on [Level2].
Click again for [off] and light will turn off and reset.
Click 5 times in UI1 [on]-[off]-[on]-[off]-[on]-[off]-[on]
and it will flash 5 options:
1 Flash - UI1
2 Flash - UI2
3 Flash - UI3
4 Flash - UI4
5 Flash - UI5
If you let go (click off) after any number of flashes,
you light will be in that mode. So if you let go after
5 flashes, you're in UI5
My advice, get a FluPIC, play with it and fall in love with it.
:lolsign:
Cheers mate !
