MattK
... feels way more reliable.
Huh? Explain please,
... the Polestar is not a thrower at all. And it has some issues.
What issues?
Yes, mine also does that on high mode, but not on low or medium. Oh well, that's electronics for ya.
What issues?
"...feels more reliable." Huh? Explain please,
One thing that bugs me though is the strobe mode.
I have also noticed that every now and then it doesn't recognize a click. I'm not sure if that is me or the flashlight, but it's not a huge issue.
The only thing is it makes a weird noise when in the high setting. It's a high pitch frequency noise. Is this normal? It's not a deal breaker or anything, but it is a little annoying. Mostly because my dog HATES it!
The only possible 'issue' in your list is the mention of sticky buttons but I searched and cannot find these posts about sticky switches.
I think mine has a goofy switch. It's gotten better now that I have pressed it On & Off 50 times, but I still will hit a CLick that either doesn't turn it Off, or doesn't turn it On.
Mine is taking a long time to change modes, at least 10 seconds, and sometimes up to 20 seconds. Beyond 20 seconds I chalk it up to the possible goofy switch and try again.
-I don't see the problem with the head contact. No complaints of them not working, failing or otherwise causing any problems.
I definitely do not have the old style carrier. Mine has clear plastic throughout, wherever plastic is used.
So now I'm thinking that when I shake it violently, the carrier's positive dimple is losing contact with the tab down near the flashlight's head. That tab looks kind of flattened down; I wonder if my shaking bent it downward. I could try to pull it up, but for now, I'll leave it alone since the light works well otherwise.
I do not associate the battery connection at the head with good quality.
Forget the battery carrier. Although not as tough as the TK40's, its by no means flimsy. The batteries fit quite snugly. Worse part, quality-wise, is the head contact. Screams "cheap"!!! :thumbsdow
I agree 100% - that was our first comment to iTp about the light.
Believe or not, I have tested 29 A6 lights in order to pick out 6 of them. And for the 6 that I shipped out, each one has been tested 3 times. Tests invloving shaking the light violently, tapping the light at the bottom and insert and remove the holder few times. In conclusion, A6's first batch battery holders' quality are quite bad.
-Your personal preference for not liking strobe is not an 'issue.'
Strobe is un-necessary and annoying to have to pass through when going from high to low. Why put strobe on a non-tactical flashlight?
Extremely annoying and utterly useless strobe mode (somehow I hate it worse than the TK40s strobe mode) which you must cycle through to get to the other modes.
-A glued battery tube is not an 'issue.'
The TK40 also costs nearly twice as much as an A6 and the A6 has a side switch which, IMO, makes much more sense for this type of light.
The A6 is also substantially smaller.
Its not normal, I just went though several A6's, no noise at all, all work perfectly. Some of you CPFers were starting to make me paranoidI just picked mine up from the post office, and I am very impressed! The only thing is it makes a weird noise when in the high setting. It's a high pitch frequency noise. Is this normal?
Well I would be more satisfied with the light if it didn't emit that high-pitched whine on high mode, but its not a dealbreaker for me and not worth the hassle of returning/exchanging it. During normal use I wouldn't be holding the light right up near my ears anyways. I don't think its a defect of the light, just a result of the electronics inside it.I was actually surprised that the first person who replied to my message said that his did the same thing. I figured that this wasn't normal, because I think most people would not be ok with a flashlight that made a noise this loud.
It might be instructive to include one's age in any post that addresses the high-pitched noise. It's well known that one's ability to hear high frequencies declines with age.
True, but with the way the UI is, you have to press the button for 2 seconds to get to the next level. So between getting to strobe, releasing the button and pressing it again, you easily get 5 seconds of annoying, anavoidable strobe, differently from other lights with a reverse clicky, for example.
What's with strobe mode anyway? Most people don't use it - leave it out or design it in such a way that it can be bypassed like the TK40!
