Re: JetBeam PA40 (XM-L T6, 4xAA, Carbon Fiber body) Review: RUNTIMES, BEAMSHOTS, & mo
In this case, I think the warning light gives an even better advance warning. Specifically, by the time the lowest mode shows even the 10% flash (i.e. 3 times in 10 secs), I would change the batteries - even if all four modes are present.
I just depleted a set of NiMH on my Maha charger's discharge function. Popped these in the light, and I got constant flashing on Turbo, slow flashing (10% warning) on Hi, Med and Lo. All four levels were present, but I noticed Turbo output started dropping immediately in my lightbox. After about 10 secs or on Turbo (which was down to ~75% max output), I noticed light began fast flashing on Hi as well Turbo (still slow flashing on Lo/Med).
So, personally, I wouldn't wait any longer than this to change the cells.
That's a good a strategy for all lights that use NiMH.This seems to be a good function. But I wonder if using lower modes could cause a risk for overdischarging the cells? When I use multi-mode lights with NiMh cells I now and then test if the highest mode still is available to see if battery is still fresh. Is that to recommend even with PA40, or will battery indicator prevent overdisharging also when using lower modes?
