Pics! And mods! And pics
of mods! (okay, just one mod.)
First of all, the Jetbeam TC-R1 benefits from a textured reflector just as much as every other flashlight ever made. Why anyone even tries to make a flashlight with a smooth reflector is beyond my comprehension, because if you really want a dedicated thrower you'll use an aspheric lense, and for all other applications textured reflectors produce nicer beams. So here's a TC-R1 with the stock reflector and another TC-R1 with a slightly-modded Arc6 (McR-18?) reflector:
I don't need to tell you which is which. Now, here's a picture of the reflectors themselves.
It looks like the custom-fitted reflector is off-center, but that's an optical illusion; it just so happens
the silicone dome on the LED is off-center while the emitter itself is perfectly-centered, which basically means there is zero effect on the beam pattern. It's a slight visual defect that has no functional consequences, so...meh.
Moving on, here's a comparison shot with my TC-R2 that I've been carrying for a year.
And here's another comparison shot, also including an Arc6, to show just how small the TC-R1 is.
Remember when Piston-Drive was the only way to make a light this small that wasn't a battery-crusher? Time will tell what the real penalty is (i.e. shorter battery life) for ditching the hardware switch, but it sure saves space, and presumably eliminates the one moving part that might actually fail and cause the light to stop working
My only complaint is the clip. I didn't realize until I got the light that the head screws
over the body, not
into the body, so the clip scrapes against the surface of the head as you loosen and tighten the head. A light this small might not need a clip, but I see a market for a super-short clip that doesn't touch the head at all. In fact, I'll say in advance that I'll buy two if someone can make them.
And now...I should try some of this "sleep" I've heard so much about. :tired:
EDIT: The tints do
not look like my beamshot shows them; I just couldn't find a color balance that captured the tints accurately. They look like typical XM-L tints, warmer in the middle and cooler around the edges.
