I'm from Europe and my native language is not derived from Latin.
The reviews forum is for questions about flashlights.
If you have any private questions,comments or want to help,it's better to send me a PM.
Cheers
Cheers
Hello;
I want to share more info about charging the battery in Klarus RS11.
Currently I use the RS11 with Sanyo 18650 protected 2600mAh.I thought to use the Sanyo in Klarus XT11 but that battery is huge and can't fit in XT11.The battery is long ~70mm and when I tried to tighten the tailcap,the bottom of the battery is being bent.
In RS11 the space for the battery is little more and no problem using long batteries in it.
About charging time-I charged a Sanyo and a Klarus battery in the RS11.When i put the batteries to charge they were at ~3.65V.Charging the Klarus18650 to 4.2V takes ~3.5h; for Sanyo18650 ~4h.
For charging I use a wall power supply and adapter/charger for my mp3 player.During charging the adapter gets hot,but it's pretty good that the flashlight stays cool.I think all this aluminum keeps the battery from heating.:thumbsup:
The adapter that I use has an led for charging status-red/green.The led turns to green a 5 minutes before the led of the RS11.
I like the fact that don't need to take out the battery when needs charging.It is very convenient.And keeps the thread not to wear screwing every day.
I charge my camera also from USB,so I have a few chargers,including in car charger.Once you get used to charge this way,you no longer want to charge otherwise.
Sanyo18650 Klarus18650
Wow, great review! The magnetic "plug?" connection looks like a great idea. Pretty much charge it anywhere. Really like the two switch interface. One thing I`m not sure about is the aggressive bezel. While not an EDC light this looks real good for home, car, camping ect. Nice general purpose light. Thanks for taking the time to do this...off to see how much they cost
Thank you!Wow, great review! The magnetic "plug?" connection looks like a great idea. Pretty much charge it anywhere. Really like the two switch interface. One thing I`m not sure about is the aggressive bezel. While not an EDC light this looks real good for home, car, camping ect. Nice general purpose light. Thanks for taking the time to do this...off to see how much they cost
This is a wonderful instrument!
I almost pulled the trigger, but paused because I have couple of questions.
First of all, this would be my first non-NiMH battery. I'm geared up to work with AA-AAA rechargables, having a couple of Maha chargers to deal with break-in, reconditioning etc.
I'm not equipped to work with Li-Ion. This would be my only way of charging and working with these battery types.
So my concern is this . . .
1) Do the Li-Ion batteries need to be cycled/reconditioned occassionally in order to keep them healthy?
2) Are there longer term issues I would need to consider for the health of the cell itself if this were my only Li-Ion charger?
I understand this is not a cell forum, please forgive me if I should be asking this in another CP forum. (I'm new here!)
Thank you,
Matthew
HelloThis is a wonderful instrument!
Thank you,
Matthew
It's a good idea,but there's no a model with three switches so far.:shrug:Is there a model with the dual head switch AND a tail switch?
That's really strange . The indicator light of my RS11 turns on only when charging-this is the normal.Check the plastic ring around the spring-is it tightened enough or is loose.I opened my(to see what's there:naughty a few minutes ago and it was really tight screwed.Question about the tail cap indicator.
I gave my son the RS11 recently and he has noted that the
tail cap light turns on red and stays red when the tail cap is screwed in firmly. if he loosens the tail cap a bit it turns green.
When charging the same thing happens -- the indicator starts red and stays red -- it never turns to green when fully charged-- UNLESS the tail cap is loosened a bit (I mean an 1/8 of a turn).
He has tried several batteries both protected and unprotected. it doesn't appear to be related to the length of the battery.
The light works fine in every other respect.
Just wanted to put this out there to see is anyone else has noted this "weird" behavior
thanks
