127.0.0.1
open it up and investigate...the tail cap is designed for end user service
the mode button is a tiny microswitch and a ganked rubber boot can cause issues,
rip it open, carefully look for aluminum thread 'whiskers' and remove any you find,
and then carefully put it back together making sure the boot and assembly is lined up
make sure the small rubber boot contact, for the small switch, lines up with
the slot in the threads, you'll see the slot when you open it up
srsly...I have 5 of these puppies and they are all flawless
Man, I just can't win. I got my XT11 back from the retailer (who said they will be happy to handle warranty claims) and the Mode switch now works again, but it has another weird problem.
When I press the main tail switch something underneath hits the mode button, too. So if I press the main switch firmly, I sometimes "double-click" something under there and it immediately drops down into medium output. If you press the main tailswitch just the right way, you can actually cycle through all the brightness modes. Sounds convenient, but it kind of sucks.
gm.
