I had just wanted to post to all those who have not and do not know anything about electrical potential. Also quit googling your information and then claiming it as if you are an electrical engineer or an expert of some sort.
It takes lower voltage and a usual result of voltage current to kill you in DC than it does AC. This is a fact as I know from first hand experience(Am a power engineer/electrical engineer) with these claims and am no amateur.
Then to break it down for those (lawliet and mr happy)
Water:________Volume_________ Pressure ___________Path of channeling(Restriction of flow)_____________
________________=_____________=______________________ =_________________________________
Electricity:_____Voltage ________Current_______________Resistance___________________________________
Also:
AC = Alternating current = DEADLY
DC = DIRECT CURRENT = EXTREMELY DEADLY
Then if DC or AC voltage doesn't matter then try tazering yourself in a bath tub and see what happens as 1kv to 100kv DC is all the same and will paralyze you thus killing you in a body of water. Also if you have been had by a leg of 220 or 430 then you would know that there is always going to be a substantial amount of current to flow along with it as its a fact of physics and nature. Momentum or current are what definitely kill you but its the weight/mass or voltage that is also doing the damage.
The rest of the factors are given constants as they have been somewhat right for a while and with a little tolerance of course with anything.
There is no weird resistance of a tube, if the body of water has a lower resistance its going to go across you faster than across the tube. Electricity acts a lot like water and air and will travel the least path of resistance. We are not trying to get a voltage out of a tube as a CFL bulb does not act as a energy storage device it only transfers and converts it.
Also there is no direct path in the body as it goes in all directions as we are made up of majority of water. It goes across the brain toes and heart all the same as its being equally distributed unless you get tons of iron in your blood and it only goes through you circulatory system...
Think twice before you make yourselves look stupid (lawliet, mr happy)
