The move follows just two months after the deaths of two children who died when they dropped a hair-dryer into the water as they played in the bath in Germany.
The sisters - aged four and six - were discovered by their mum when she realised their bath time play had gone quiet suddenly. Paramedics in Lustadt were unable to revive the girls who electrocuted themselves when they dropped a hair dryer into the tub.
Im pretty sure that uk has strict standards of gfi's and metal piping...
This is a news story none the less...
Ok, while ANY avoidable death is tragic...
UK standards
really have no bearing on systems in
Germany. And homes
anywhere on the european continent can be
hundreds of years old; meaning cobbled together infrastructure. Although of any country I would expect Germany to be the most squared away, with the exception of the former East Germany.
Im sure the ac will kill you with sufficient current...
Dc will do it at a lower voltage and current...
I correct myself as stated above(sorry about the rude comment(s))....
The laptop would short out and render useless.
What if the user tried grabbing the ac cord with wet hands and then this is the game ender. Otherwise the laptop would not kill you but shock you a little but as most have said on here it only takes 36v to kill a person.
Here's another scenario since water alone has a high resistance. What if the water were softened by salt and then would make the water highly conductive. then the human in the water would have a higher resistance and then poof. Could this change the scenario?
Again, I was an eyewitness AND participant in a routine experiment given by a public safety training group (PATC).
The instructor put a turned on and running blow dryer (plugged into the wall) into the water. Whereupon the GFCI plug on the BD did not open, instead the BD kept running and began to heat and circulate the water. All this time the instructor held the BD and/or the cord with one and/or both wet hands as he splashed merrily away astonishing approximately 50 fire/arson investigators. He then asked for a volunteer, everyone was still skeptical so I did.
He called me up and told me to put my hands in the water. I did so and am still here typing this post today, that was 5+ years ago. The water was pleasantly warm....
As I previously mentioned, water softened by salt will give you a 'tickle,' per my personal experience at home via the demo for wifey. Our water averages 100+ grains of hardness prior to softening requiring a 'commercial' system and uses A LOT of salt. I don't know how much is in the water but I know you don't want to drink it! :sick2:
As a refresher I built my house in 2001 and dad & I put in PVC D/W/V and poly supply tubing,
no ground potential through the plumbing at all. I get zapped a LOT harder by the 'electro-stim therapy' I get at the chiropractor.
If you're gonna end up in the water with electronics I recommend CLEAN and
naturally SOFT water.
