So is the MH27 still top of the list? I still haven't bought one yet
The MH20 GT has more throw . More edc IMO .
That would be a huge crawl space or attic. MH20 at 220 meters throw . MH20GT at 362 meters Nitecore website . I have no way to verify
Flashlight | Candela | Notes |
Olight M2X-UT Javelot | 164,000 | Source: OlightWorld. This CPF post says highest output is obtained with 2x18350. Output dims faster on 1x18650. |
Acebeam T20 | 275,500 | Source: Acebeam. Candela measured using 2x18650 (LG HE2 2500mAh). |
Vinh's M25C2vnT | 800,000 | Source: Alex1234. This flashlight is not listed at SkyLumen.com. |
Eagletac T20C2 Mk. II | 11,500 | Source: Eagletac. Posted candela is for Cree XM-L2 U2 emitter. Candela should be higher with Cree XP-G2 R5 emitter. |
Nitecore MH27 | 53,500 | Source: Nitecore. |
Olight M23 Javelot | 47,500 | Source: OlightWorld. Runtime chart in User Manual shows early step-downs. |
Eagletac T25C2 XP-L HI | 33,100 | Source: Eagletac. |
BLF D80 | 38,250 | Source: DB Custom. |
Eagletac M30Cvn KIT | 155,000 | Source: SkyLumen. |
Eagletac G25C2 MKII | 41,200 | Source: Eagletac. |
Nitecore P12GT | 25,700 | Source: Nitecore. |
Fenix E35UE | 6,100 | Source: FenixLight Limited. |
EagleTac S200C2 XP-L HI | 58,400 | Source: Eagletac. |
Nitecore MH20GT | 33,000 | Source: Nitecore. |
Lumintop SDmini XP-L HI | 22,500 | Source: Lumintop. |
Eagletac P25LC2 XP-L HI | 25,400 | Source: Eagletac. |
BLF Kronos X6 Cu/SS | 52,000 | Source: DB Custom. Emarkd measured the same flashlight at 58,600cd. The copper/stainless-steel version is also sold as the Astrolux SS. The less expensive aluminum version is sold as the Astrolux S2. |
Convoy C8 HI | estimated more than 60,000 | I could not find a source for the candela, however, with a larger reflector, it should be higher than the Astrolux S2. On the other hand, the stock Convoy driver does not drive the emitter as hard as the Astrolux does. If you buy your Convoy at Mountain Electronics, you can specify an upgraded driver. |
Are any of the handhelds from zebralight any good?
