Re: Learning to lathe
I'd like to thank TB and will for pointing out how dangerous a lathe can be, especially when you are learning on your own, or through books only.
Needless to say, I have had mishaps, almost all of them resulting from either misusing a tool, or taking too deep a cut on an unstable piece.
I do try to be real careful, double or triple checking the chucking tightness, runout, clearance, etc., etc., and most importantly, I try to keep my hands away from any spinning part.
So far, so good.
OK and now today's lesson.
Wanted to try an idea that I had for a head which would involve cutting on an angle and then feeding a tool into the tapered part to create a pattern. Worked pretty good until it came time to part it off, when I decided to try a new parting tool. Mistake! I should have practiced with the new tool on just a plain bar first, not on my almost complete part. Another day, another lesson learned. :-(
Still I managed to salvage enough to say that I do want to try this as a production idea:
And from a different angle:
Sorry about the focus! And finally, my last chance to bore you to tears. :lolsign:
In case you were wondering, no, the head was not designed for a CR2 light, something much bigger really. I just used the CR2 battery since the proto fit so well on it.
