Ron are you sure those were LED ropelights? I think I know the suff you mean- solid tough tube with the lights moulded into it. But normally it has tiny long life bulbs inside, not LEDs- try this- when the stuff is off, are they all clear "bulbs", then they light up multicoloured, or are they all coloured when off too? If they`re coloured when off, you`ve got bulbs there, 99% certain. I used neon ropelight in 1999-2000, it`s very nice but not the same as "regular" xmas lights in my opinion. Looks a bit "commercial" and unless you have it secured perfectly straight along wherever you`re running it, it can end up not looking so good. I may use it again though, not sure.
Course you could prove me wrong- it`d be nice to see LED neon ropelight. Any way to take some up-close macro pictures? I`ll dig one of my lengths out later and do the same.
Incidentally I got hold of some great LED lights recently from UK electronics supplier Maplin Electronics. I believe they ship overseas but like everything in this land of ours, they`re very expensive! Still you`s lot may like to see them.
All-White plain bulbs or All-Blue clear stars! Only drawback is they have one of those annoying multi effect pushbutton controllers that won`t remember the last setting it was on when you turn the power off- so I`m going to fit a connector so I can remove it and connect straight to the 24v transformer if I don`t want effects.
White. Look like Nichia parts, with specially molded inverse-conical tops to spread the light out. They`re from a lucky-bag of colour ranks it seems, I see slight subtle tints of greens, blues, pinks and yellows, much the norm for white LEDs and quite attractive really! Overall though, a nice cold icy white....
<center>
</center>
<center>
</center>
Blue. Possibly Nichia 3mm moulded into those stars which diffract the light all around. Wonderful colours, two distinct ranks it seems- some are the more common slightly cyan-tinted Nichia blue (like the Photons), and some are a stunning deep blue (like the ASP Sapphire), almost violetty in fact- not far off the wavelength of those deep blue narrowband Kingbright LEDs Craig sells on his
LEDs For Sale page.
<center>
</center>
<center>
</center>
<center>
</center>
Watch out for these being used in my lights display this year- a seperate web site about my xmas displays is being worked on right now and will be accessible from my homepage in due course.
One concern I had with these- these LED lights
came with spare LED bulbs! And what`s more, one of the white LEDs was out, so I needed one of the two spares suppled with the set!
<center>
</center>
Well, not quite out, but very dim- but it was like that out of the box. No need to make a fuss and have to ship`em back for a new set so I just changed it over. So far so good but I`m a little concerned that more will fail, the white set I`m keeping a close eye on- it`s hung up in here already. Great colour!
If you want some of your very own you can get them from
http://maplin.co.uk for a whopping GB£30/set of 56. Not sure of the avaliability at present, but they better have at least one more of each cos I like`em so much I`m going to use one set in each of the four main windows at the front of our house. Good that I have a mainly blue and ice-white colour scheme this year!
