I highly doubt that those DX optics produce a gradient beam pattern, which is key to an ECE style beam. Please correct me if Im wrong!
My proposal is:
With LEDs getting brighter and brighter the default 'circular' beam is getting dazzling to on-coming drivers and all that light above the horizontal could be better used lighting the road and roadside hazards.
There is no reason why the proposed light could not be used alongside a powerful circular beam in the same way that cars have dip and main beams.
It looks like the Hella HL 2000 uses a collimating optic, yet Peter White reports that it produces an ECE style cutoff beam with gradient brightness:
Does anyone know more about the optic used in this light?
-Jim G
Hows about something with a beam like this
This is just a test rig I am working on experimenting with different sizes of acrylic bar
Now if you used a larger diameter bar and put 2 rows of leds one row dead centre and the other row above and maybe even less leds then to dip switch the centre off and the top on this then drops the beam a good amoumt this i hav not got round to testing yet.
maybe there is the possibility to design and build an own reflector, like this one in the cyo?
I don't think there are many people who could design and make such a reflector - or a similar total internal reflection optic.
I was thinking about this the other night and was wondering about 2 different things:
1) Forming the appropriate surface somehow and then using strips of chrome tape to make it reflective - like this 24" reflector, but smaller.
2) Use an oven to hand form acrylic/plexiglass mirrors, like in these videos: DIY Plexiglass Mirror and Oven forming acrylic.
The profile on the Edelux/Cyo mirror looks like it wouldn't be hard to form:
I may make a trip to tap plastics this weekend - the cutover in daylight savings is motivating me to get some more lights on the bikes.
By the way, I think using some bondo/putty to form the prototype mirror backing with some chrome tape for the surface would be a good first pass.
Its not actually about getting it done faster - I've got a D'Lumotec and just built an auxiliary light to go with it that will be more than adequate for commuting, or even evening training rides (assuming I can get my sick rear out on the roads in the evenings). At this point is mostly a hobby/challenge. I will need one more light for a bike that I am slowly building up and I could afford to just buy an Cyo or Edelux and be done with it if I didn't think this just an interesting problem that _should_ be solvable by hobbyists.You can get an IQ Fly from White for ~75$. If I wanted to have an StvZO reflector to play with, I'd do it that way. Much faster.
Remember a few things.
Reflector surfaces are fragile. There is a really good chance that taking a mold from a Cyo/Fly/Edelux reflector would destroy it. Anything that gets on that surface will have to be cleaned, and how are you going to do that?
Reflectors are designed with a very specific source, in a very specific location. Swapping an XR-E for an MC-E, for example, changes the throw pattern significantly. Changing an XP-E to an XP-G has major consequences. Likewise moving the emitter w/respect to the reflector. If you look at an H-4 bulb, the high and low filaments are separated by ~3mm, in a much larger reflector.
SFCyclotourist said:I just watched a different video by the same Green Power Science guy where he demonstrates constructing a parabolic mirror using the bottom of a steel drum for the base parabolic shape, filling that with concrete to form a positive mold, and then laying plexiglas over the concrete mold to form the mirror's back. Finally, a two-part mirrored mylar was used inside the plexiglas parabola to create the reflective surface.
http://blog.makezine.com/archive/200...ic_mirror.html
Hi Martin,
Thanks for pointing that out. It looks like they offer the option on their dynamo light as well, as the "glare free lens".
Interesting beam pattern. I think this posting is about one user's impressions of it:
(1)
Fahrräder müssen für den Betrieb des Scheinwerfers und der Schlußleuchte mit einer Lichtmaschine ausgerüstet sein, deren Nennleistung mindestens 3 W und deren Nennspannung 6 V beträgt (Fahrbeleuchtung). Für den Betrieb von Scheinwerfer und Schlußleuchte darf zusätzlich eine Batterie mit einer Nennspannung von 6 V verwendet werden (Batterie-Dauerbeleuchtung). Die beiden Betriebsarten dürfen sich gegenseitig nicht beeinflussen.
Probably not, the 'bat signal' is almost certainly the earlier version. I do't know if they redesigned their lens, but the previous one was rather poor. See
http://nabendynamo.de/service/pdf/ar_11-12_2008.pdf
But with the $15 E6 replacement reflector from Peter White you can get something approaching the E6 beam pattern?
