Li-ion "D" cells
JwSantora
Colorado
I've not had any luck in finding any sources (under 1000 pcs) for rechargable Li-ion cell in D size. Anyone have a lead?
Joe
flashflood
Joe
The main reason you won't find Li-ion D cells is that D cells are 1.5V, and Li-ion is 3.6V. You can find NiMH D cells, which are 1.2V, though these seem to have fallen out of favor. What application are you trying to solve?
desert.snake
Eastern Europe
They exist, they has name - CR34615
or
EVE CR34615 battery
Saft LS33600 battery
Ultralife U3356H battery
but they are not rechargeable
As far as I remember, here someone had adapters from a D battery to 2 * 18650 or 2 * 18500
something like this
vicv
Southern Ontario
D is just a designation. And yes, there are d sized, or 32650, lithium ion batteries. Using 32650, should easily net you something on a google search. How good they'll be I don't know, none of the big manufacturers make them in this size.
lampeDépêche
As desert.snake says, most (all?) of the lithium 3v batteries in that size are primary, non-rechargeable.
Be careful with the Saft -- they do not support a high current draw, and also have an uncommonly toxic chemistry (Li-thionyl chloride). Some good properties for low-drain, long-life purposes, but not a good choice for flashlights.
If you really want a rechargeable in this format, your best bet may be to find a parallel carrier for 3x14500s. It's not ideal, but it gives you the right chemistry and voltage, and it's rechargeable.
vicv
Southern Ontario
Why does he need 3V cells? He's asking for lithium ion. If you can find 3.6v 32600 that's what you want. 32650s will work in something with springs too. Like a maglite in some instances
There are Also a multitude of LFP cells in this size
desert.snake
Eastern Europe
knucklegary
NorCal, Central Coast
HKJ found a large variaration in capacity between the two Soshine test cells. Way too large to safely run (unprotected) cells in series
Unless you find protected cells, I'd buy a few 32600 and test them for 2x cap matches
*Chinese companies with Trust in the name I would totally pass on
vicv
Southern Ontario
In this case I think 18650s in a spacer would be better. Just turn around the tailcap spring to make up for the added length. And I've gone the 5 cell bulb route. The 6 cell xenon is the better bulb in my experience. The pr version. I hear the bipin is even better
fivemega
California
I have few of these:
Bored out 3C M*g to fit 2x26650 or 2x21700 in PVC tube.
Outside barrel grooved for better grip.
Hard anodized.
Switch contact with flat top or button top batteries.
No further modification needed.
Please contact me if anyone interested.
knucklegary
5mega, running 2x protected cells are you using ML stock heavy coil tail contact spring?
Or do you machine a Cu disc, to fit on spring end, acting as a buffer against soft cathodes?
fivemega
California
These are new older 4C with 2" head, shortened, rethreaded, inside bored out (to fit protected 26650) and outside grooved incand M*g with "C" in front of serial number. (Thick wall tubes)
Tail cap and spring is not machined or modified.
alpg88
You do not see a lot of them cuz no reputable brand (lg samsung, sony, panasonic, sanyo) makes them. there are some on the market, made by others, and some are not bad at all, but there isn't really a big demand for that size. i still have 3 out of 7 that i had (4 failed). but when they go i'll get 21700.
