About the lithium-manganese spinel batteries used in the Chevy Volt, They have already proven to be a safety hazard by errupting into flames 2 weeks after a crash test was done. Cause in this case was in fact determined to be the batteries. While it may be possable to create an unsafe condition for LiFePo4 batteries you have never heard of a true LiFePo4 powered hybrid car bursting into flames due to a battery malfunction where the battery itself ignites on its own after receiving abuse or been involved in a crash. That does not mean that there could not be a fire but it would not be caused by the battery itself igniting first. Fire could be caused by an electrical short which ignites the insulatin of the wiring due to the very high current capacity of LiFePo4 batteries but this is not the fault of the battery itself bursting into flames as it was with the Chevy Volt.
LiFePo4 still seemes to be the safest option & higher capacity is possable with this chemestry as proven by the LFP123 batteries from K2. These actually performed up to my expectation of what any lithium ion battery should have been capable of but till the K2 experiment I ran none lived up to as far as the CR123a battery size was concerned. All fell short by a substantial amount but not the K2's. The K2 LFP123 batteries do exchange current capacity for energy density though in this particular size. These are not the high current batteries that K2 makes in thier other sizes & are only rated for Cx2 for discharge rate. But under the circumstances I can see why they made that decision. Note that all the other K2 battery sizes are rated for greater than Cx2 discharge rates, even thier high energy versions as opposed to thier high power cells.
