VidPro
in other words the parameters are there because that is what it works the best in. the directions, like leaving one 40% discharged , exist because that is what works good. its good to charge it (cycle like) before you use it, and you cant store it to low, or it would drop to far.
they cant have a 3.0V dropout on protection, because under a normal hard load, that might be to high for the voltage dropps that normally occur.
its worked out pretty good if you ask me, when i vary from the parameters, is when it is not effective.
so the way they set it up, with the curcuits, is the right way, and i have tried the wrong way (somebody had to), and it aint better.
