Looking for a Malkoff LLLL drop-in
Sarkis
Clovis
I just purchased an m61WLL, and I really like that warm low output light. I added a hi/low ring, but it didn't drop the lumen as much as I thought it would, it was a slight difference, but on my m61hot, m91b, and super, it is a larger difference. Does anyone have one to sell possibly?
RWT1405
PA
My M61NLL's (2-L's) on "low" (via Hi/Low ring) have a noticeably lower output then my M61NLLLL's (4-L's).
Others may have different experiences, but this is what I have found.
Sarkis
Clovis
Here is what I just found out. I was testing the m61wLL on the md3, and low was not a drastic difference. I then tested it on the MD2 and the low was much lower than it was on the Md3 on low. This might be a dumb question but will the higher voltage brighter light on the md3 with two 18500's (2300mAh) last longer than the lower voltage single 18650 (3500 mAh) on the md2 both on low with the md2 having lower low output?
-RWT1405, were you testing the on testing the M61NLL with Hi low ring and the M61NLLLL on the same body
troutpool
Arizona
In my experience, the LLL with Nichia emitter is a little bit less bright than the LLLL. You could consider that as an option, and it is usually available to buy at illumn.com.
Sarkis
Clovis
All the illumn drop-ins say they are out of stock when it's in the cart, darn.
If anyone has any malkoff drop-ins let me know
RWT1405
PA
Sarkis,
This might be useful for you.
RWT1405
PA
Also this,
Thanks to dotCPF for the info in both posts!
