You seriously think the flashlight would hit the $2000 mark? Put it like this, if it did I would not be able to afford it, however I am also unwilling to put down a budget as a lot of people I have dealt with or seen on the net will immediately quote your maximum budget (notably script writers that I have dealt with in the past on sites you need to set a budget on) - I'm not saying anyone here is untrustworthy at all, it's just the way I work. I have also already ruled out HID lights because of the high bulb replacement rate and cost. I like the idea of 50,000 (heck, even 5000 hours) of light. Changing bulb in the middle of a field in pitch black is not fun either... I'm also toeing the water at the moment to see if anyone would be up for building a compact(ish) 3000 lumen led torch
The issue with the HID bulb life is only if you drop it. The bulbs are good for 2-3,000 hours on high. If you run it for one hour every night, that is 8-10 years assuming you work the same number of days as the rest of us. At $50 a bulb, that is pretty cheap. Let's say a customer LED flashlight is going to be $500.... you could find a HID in that price range... you do not need a $2,000 military quality one.
I think you need some more data on the power requirements. The Seoul P7 and the Cree MC-E are both quad die devices. The Seoul is 4 devices in parallel, the Cree is 4 in series. From your standpoint (i.e. I just want to buy a flashlight), it really does not matter. That is for someone else to work out the electronics. However, from a simple standpoint, when you want to get say 700 lumens out of either device (about what they are capable of today ....guarenteed lumens), then you need about 10 watts to get them to that point. Hopefully when the MC-E ships it will be higher than 700. Seouls top bin is higher, but for interests sake, tell yourself you will get about 700 lumens per LED at about 10 watts. If you run 4 of them, you will need 40 watts to power them. Let's assume you can get 85% driver efficiency. That means you will need 47 watts or so to run your LEDs. A single 18650 Lithium can put out about 6-7 watts for an extended period of time without damaging the battery and while still maintaining good battery life. Hence, you could comfortably run your flashlight on 8 of them and I would not feel uncomfortable running it on 6. If you want to keep the size down, you could use A123 cells which comfortably put out much higher currents. You could easily run on 4. So that is what it takes to RUN your flashlight. Now lets look at life. An 18650 battery will have about 6 watt hours of power when it is running the currents you need (give or take 20%). If you have 8 batteries, you have 48 watt hours. 8-18650 batteries will hence run your flashlight flat out for about 1-hour. Go down to 6 and you will get less life of course.
Last thought. Your 500 lumens flashlight that runs on 4 R123s. I am not sure what LEDs are in it, but I pretty much guarentee it is no where near 500 lumens for a full 4 hours. Each R123 has about 2-2.5 watt hours so you have about 8-10 watt hours of batteries in your light. I would hazard to guess that for 500 lumens, you are likely drawing about 5 watts. Hence to actually get 500 lumens, you could only get maybe 2 hours. Depending on the driver, you may be dropping below 500 lumens pretty quick. Perhaps a flashlight that puts out a true 1000 lumens and keeps it there for an extended period of time would be enough.
Semiman
