Lumintop TD-15 Terminator (XP-G R5) Thrower Review: RUNTIMES, BEAMSHOTS and more!
selfbuilt
Written by ManChow on 01-04-2011 11:05 PM GMT
Sorry some shots are out of focus, I found that this is not easy to capture when I am not focus on the hotspot, apologize if any in-convenience occured.
Written by ManChow on 01-04-2011 11:15 PM GMT
Group Two: (20metres)
selfbuilt
Re: Lumintop TD-15 Terminator (XP-G R5) Thrower Review: RUNTIMES, BEAMSHOTS and more!
Written by ManChow on 01-04-2011 11:23 PM GMT
Group Three: (50metres)
Written by ManChow on 01-04-2011 11:35 PM GMT
Group Four: (100metres)
Principle Environment
Vehicle Heamlamp
List of Flashlights
selfbuilt
Vehicle Heamlamp
List of Flashlights
Written by ManChow on 01-04-2011 11:49 PM GMT
BeamShot Bright Level Comparison (2metres)
From Left to Right
Fenix TK12
Fenix LD40
Lumintop TD12
Lumintop TD-15
Lumintop TD-15X
Written by ManChow on 01-04-2011 11:56 PM GMT
TD-15X(Left) vs TD-15(Right) - 2metres
Fenix TK12 (Left) Vs Lumintop TD12 (Right) - 2Metres
Written by ManChow on 01-05-2011 12:08 AM GMT
Degree of illumination
TD-15X Two metres Hotspot
3940Lux (1x18650 - High Mode)
4510lux (3x16340 High Mode)
112.4Lux (2x18650 Low Mode)
1538Lux (2x18650 Middle Mode)
4570Lux (2x18650 High Mode)
selfbuilt
Written by ManChow on 01-05-2011 12:29 AM GMT
Flux Comparison - Ceiling Bounce Test
(Same Environment, Same location of the object - Flashlight count on glasses to the ceiling, the distance are identical, fixed light output and the Lux gauge location, says flashlight output 2metres to the ceiling, 1metres upper than the gauge and 1metres the distance)
selfbuilt
Written by 276 on 01-05-2011 12:36 AM GMT
Great photo's. i really like the looks of the TD-15X
Written by ManChow on 01-05-2011 01:04 AM GMT
Thanks of Funder - A Famous Flashaholic located in Singapore, he teached me how to evaluate the approx. Lumens, under my figures to provided.
If Fenix is under the ANSI Standard to mark the flashlight Lumens, I think the below data also have some reference value.
Brand(Model) / Brand Claimed (lm) / Ceiling Bounce / Evaluate Value
1. Edi-T P4R R5-1A 1.3A 63000 / -- / 6lux / 84lm
2. Fenix TK12 R5 / 280lm / 18.4lux / 257.6lm
3. Lumintop TD-12 R5-1C 1A / 330lm / 17.9lux / 250.6lm
4. Lumintop TD-15 R5-1A 1.5A / 420lm / 24.2lux / 338.8lm
5. Lumintop TD-15X XM-L T6-1A 2.5A / 580lm / 48.2lux / 674.8lm
6. Fenix LD40 R5 / 248lm / 21.8lux / 305lm**
7. Tiablo A10 R5 / 320lm / 13.5lux / 189lm
8. Taclight T5 Q5-WC / -- / 14lux / 196lm
9. Olight M31 SST -50 / 800lm / 49lux / 686lm
10 Olight SR50 SST-50 / 800lm / 31lux / 434lm
**My Fenix LD40 is equipped with R5 Led instead of R4/248lm they claimed
Written by ManChow on 01-05-2011 01:26 AM GMT
Beamshot Comparison
I've produced three group of test, 2,5,15metres respectively, each test also provided the degree of illumination.
List of Model to compare: (Same as the model of outdoor comparison)
Group One - 2metres
Degree of illumination - centre of the hotspot
selfbuilt
Written by ManChow on 01-05-2011 03:01 AM GMT
Battery Side's Current Measurement (TD=15X)
When talking about what's a flashlight actual output current driven , we only can detach the LED +/- welding, and measure the exact output current from the circuit board directly. But the fact is, sometime this is hard to measure it, since many Brand's of flashlight was bonded the head to prevent DIY'er detach the flashlight and void the warranty.
As a result, usually we will measure the battery side's current driven (input), to evaluate the maximum output current driven, this will incurred many figures: the efficienty of circuit board, the VF value of LED, total input Voltage etc., an expert (not me) can be easily to determine...
1x18650 (4.2V) High mode
2x18650 (4.2V x 2 = 8.4V) High mode
3x16340 (4.2V x 3=12.6V) High mode
Written by ManChow on 01-05-2011 03:22 AM GMT
Runtime Testing (TD-15X)
Battery:1 x 18650 (Sanyo 2600mAh)
Starting Voltage: 4.2V
Ending Voltage: 3.1V
Starting Illuminance (1metre): 18780Lux
Ending Illuminance (1metre) : 9390Lux
Maximum Surface Temp.:39 Degree (Occured around the 25min of runtime period)
Runtime: 1 hour 41 min(Based on ANSI Standard,Runtime count from 100% to 50% Brightness level)
@10 minutes captured diagram
Ending Voltage
Chart of Illuminance/time
selfbuilt
Written by ManChow on 01-05-2011 03:33 AM GMT
Runtime Testing II (TD-15X)
Battery:2 x 18650 (Alfa 2200mAh Protected)
Starting Voltage: @4.2V
Ending Voltage: Front 0.00V Rear 3.64V
Starting Illuminance (1metre): 24800Lux
Ending Illuminance (1metre) : Suddenly dropped and light off
Maximum Surface Temp.:57 Degree (Occured around 75min of the runtime period)
Runtime: 1 hour 28 min
Written by ManChow on 01-05-2011 03:43 AM GMT
Runtime Testing III (TD-15X)
Battery:2 x 18650 (UltraFire18650 2400mA)
Ending Voltage: Front 2.52V Rear 2.57V
Starting Illuminance (1metre): 28800Lux
Ending Illuminance (1metre) : 27000Lux (Light output becomes unstable)
Maximum Surface Temp.:53 Degree (Occured around 50min of the runtime period)
Runtime: 55 min
@5 minutes captured diagram
Written by ManChow on 01-05-2011 03:54 AM GMT
Runtime Testing IV (TD-15X)
Battery:2 x 18650 (ICR18650 2200mA)
Starting Voltage: @4.19V
Ending Voltage: Front 0.00V Rear 3.23V
Starting Illuminance (1metre): 28000Lux
Ending Illuminance (1metre) : 26500Lux (Suddenly dropped and light off
Runtime: 90 min
Written by ManChow on 01-05-2011 04:04 AM GMT
Runtime Testing V (TD-15X)
Battery:2 x 18650 (Feilong18650 2600mA)
Starting Voltage: @4.22V
Ending Voltage: Front 2.3V Rear 3.22V
Starting Illuminance (1metre): 28400Lux
Ending Illuminance (1metre) : 17100Lux (Suddenly dropped and light off finally
Maximum Surface Temp.:57 Degree (Occured around 100min of the runtime period)
Runtime: 105 min
Written by ManChow on 01-05-2011 04:16 AM GMT
Runtime Testing VI (TD-15X)
Battery:4 x CR123 (Cytac 1500mAh)
Starting Voltage: @3V
Ending Voltage: Front to Rear 1.62V 2.08V 2.19V 2.43V
Ending Illuminance (1metre) : 26100Lux (Suddenly light off)
Maximum Surface Temp.:61 Degree (Occured around 60min of the runtime period)
Runtime: 60 min
Runtime captured diagram
Cytac CR123(1500mAh)
Ending Illuminance (1metre) : 26100Lux (Suddenly light off afterward)
Written by ManChow on 01-05-2011 04:41 AM GMT
I also want to bring up another Flashaholic the comparison - dengtuzi, which is located in China, he'd gathered 3's of XM-L based Flashlight: Fenix TK35, Olight M3X and Lumintop TD-15X.
Group One - Ceiling Bounce Test
22W Philips Light Bulb - 44lux
Fenix TK35, Claimed 820lm, 114lux
Olight M3X, Claimed 700lm, 107Lux
Lumintop TD-15X, Claimed 580lm, 101Lux
Lumintop TD-15X, 2*16340, 101 lux
Lumintop TD-15X, 1*18650, 80 lux
Lumintop TD-15 R5, 1*18650, 47 lux
Written by ManChow on 01-05-2011 04:44 AM GMT
Group Two:
selfbuilt
Written by ManChow on 01-05-2011 04:48 AM GMT
Group Three:
Written by selfbuilt on 01-05-2011 09:15 AM GMT
Wow, that's a lot of photos ManChow. :eek:oo:
FYI, you might want to consider re-posting them in their own thread in the main LED forum. Members here are always looking for comparative pictures of various lights, and I'm afraid these will get lost in p.6 of my TD-15 review. It would be good to have them in their own thread somewhere.
Cheers! :wave:
Written by ManChow on 01-05-2011 09:34 AM GMT
Cheers! :wave:
Oops!! Sorry Sir, I am your fans anyway. Aim to reduce the resource of the Forum, I just only want to make use of your thread to introduce and compare this brother model to all Flashaholic's, pls forgive me if any in-convenience caused. Oops!! Sorry Sir, I am your fans anyway. Aim to reduce the resource of the Forum, I just only want to make use of your thread to introduce and compare this brother model to all Flashaholic's, pls forgive me if any in-convenience caused. :thanks:
Written by selfbuilt on 01-05-2011 10:09 AM GMT
No inconvenience - the photos are great. I just think they should be in their own thread for more visibility - especially for all the other lights included. No inconvenience - the photos are great. I just think they should be in their own thread for more visibility - especially for all the other lights included. :)
Written by brightnorm on 01-05-2011 01:31 PM GMT
Manchow,
I just ordered a 15X based on your comprehensive and revealing photos. I agree with Selbuilt's comments; your photos constitute a review and should have their own thread
Brightnorm
Written by ManChow on 01-05-2011 10:26 PM GMT
Hi Brightnorm,
Thanks of your comment, I will consider the necessity of to separate an individual review for TD-15X, my preliminary idea to combine the review that is because the information I posted also consist many figure's of TD-15.
Regards,
ManChow
Written by lautamas on 01-06-2011 12:40 AM GMT
I am surprised to see you here manchow.
I am a fans as well to your work in shoudian.com
Thank you for the great pictures. I think we need Thrunite XM-L (altough it belongs to a different class) to compare this into
Written by FLT MEDIC on 01-06-2011 04:26 AM GMT
ManChow said:
Hi Brightnorm,
Regards,
ManChow
Hi ManChow, Hi ManChow,
Many thanks for the comprehensive data and pics, much appreciated! I agree with Selfbuilt and Brightnorm, the TD-15X should have it's own review thread so it will be easy to search for in the future. Just copy and paste your posts into a new thread. :)
Written by selfbuilt on 01-06-2011 09:20 AM GMT
FYI for those interested, I will be testing the TD-15X as well. But it will likely be a couple of weeks before a review is up (I have a bunch of other reviews in the works first). :wave:
Written by Cuxhavener on 01-06-2011 04:54 PM GMT
ManChow said:
TD-15X fully support 1x18650, 2x18650, 2xCR123, 2x16340, 1x18650+1xCR123, 1x18650+1x16340, 3xCR123, 3x16340, 4xCR123...at your convenience.
Do you mix 18650 and 16340 in the TD-15X? Do you mix 18650 and 16340 in the TD-15X?
Written by surprise! on 01-07-2011 04:38 PM GMT
(moved tohttp://www.candlepowerforums.com/vb/...19#post3647319)
Written by FireHawk007 on 01-07-2011 05:41 PM GMT
Can't wait for the testing, Selbuilt as I'm highly interested in TD-15.
Written by alk007 on 01-09-2011 08:28 AM GMT
I did some measures yesterday:
Lumintop TD15 (XP-G R5)lm/1m:
. . . . . . . . . . . . . . . . 1 x 18650 . . . . . . . . . . . . . . . . 2 x 16340
Mode: . . AW 2900mAh . AW IMR 1600mAh . AW 750mAh . AW IMR 550mAh
Turbo . . . . 15 440 . . . . . . . 15 200 . . . . . . . . . 15 180 . . . . . 15 340
High . . . . . 13 250 . . . . . . . 13 300 . . . . . . . . . 13 440 . . . . . 13 450
Medium . . . . 6 260 . . . . . . . . 6 410 . . . . . . . . . 6 550 . . . . . . 6 560
Low . . . . . . . . 381 . . . . . . . . . 384 . . . . . . . . . . . 387 . . . . . . . 394
Written by dave29 on 01-09-2011 06:15 PM GMT
Awesome review!
I was getting ready to order an Olight M20s or Fenix TK15 when i found this review on google searching for some last minute info on which to decide on.
Now I don't know what I am going to get, but I am leaning toward this light. I really like how you can add to the body for more battery capacity, among other things. :)
Written by brightnorm on 01-17-2011 11:28 PM GMT
Will you have the opportunity to test with 3xCR123? From the standpoint of carry this length is a nice compromise between 2xcr123 and 2x18650 and I suspect the runtime, especially on medium, might be pretty decent. Will you have the opportunity to test with 3xCR123? From the standpoint of carry this length is a nice compromise between 2xcr123 and 2x18650 and I suspect the runtime, especially on medium, might be pretty decent.
Brightnorm
Written by selfbuilt on 01-18-2011 08:01 AM GMT
I will definitely test 3xCR123A/RCR, but don't usually do Med on CR123A (i.e. I tend to limit primary runtime tests, as the cells get expensive fast!). But I'll see what I can do in this case. I will definitely test 3xCR123A/RCR, but don't usually do Med on CR123A (i.e. I tend to limit primary runtime tests, as the cells get expensive fast!). But I'll see what I can do in this case.
Written by Mezza on 01-18-2011 12:30 PM GMT
I have finally narrowed it down to either the TD15 or the Fenix TK15, can anyone advise which will be superior? Will be used for hunting, and as an EDC.
I will use one 18650 battery either one. Thanks.
Written by brightnorm on 01-18-2011 02:00 PM GMT
I have both lights. The Fenix TK15 is not designed as a real thrower. I would class it as avery superior general use light with excellent throw and spread. It is very bright (total output). I'm not a hunter so I don't know what your requirements are. If you need throw, the Lumintop TD15 is among the best throwers in its size category. The TD15X is remarkably bright, so bright that even though its beam is more diffuse than the TD15 it throws remarkably well, though not quite as far as the TD15. The disadvantage of the 15X is that for regulated runtime you will have to use at least one extension which makes it about
7-1/8"(181mm) long, whereas the TD15 functions fully in its original 5-7/8" (149mm) configuration (1x18650/2xcr123).
Brightnorm
Written by brightnorm on 01-25-2011 12:41 AM GMT
Question:
Can the TD-15/15-X strike bezel be removed (by a non-technical person) and will the lens still be retained?
Brightnorm
Written by selfbuilt on 01-25-2011 07:13 AM GMT
No, the bezel holds the glass lens in place. No, the bezel holds the glass lens in place.
selfbuilt
Written by jake25 on 01-25-2011 03:40 PM GMT
brightnorm said:
Question:
Brightnorm
That is how the L series of the Lumintop lights are, but not the TD series. That is how the L series of the Lumintop lights are, but not the TD series.
Written by brightnorm on 01-25-2011 05:18 PM GMT
Thanks for those answers.
BN
Written by brightnorm on 01-26-2011 10:39 PM GMT
Just a note to say I have been EDC'ing the TD-15X in a 3xcr123 configuration for the past week in a Ripoffs belt holster. I believe it is an excellent compromise between the 1x18650 and 2x18650 versions both ergonomically and functionally. I find its broad but very powerful beam ideal for general use at all brightness settings. I wish it had four or even five brightness levels (like the Quarks). Perhaps that might be possible in future versions.
There are several belt-holster options for the 3xcr123 version. I don't care for the regular TD 15 holster though; the elastic is too loose-fitting for a secure grip so I wouldn't bother cutting the bottom to accomodate the 3xcr123 version. I've found that the ideal holster for the regular length TD-15 is the one that comes with the Fenix TK-15. A longer version of this would be perfect for the 3xcr123 TD-15X. Using the most compact holster, carrying the TD 15X 3xcr123 is surprisingly comfortable and convenient.
Here are three Ripoffs holsters that will fit the TD-15X/3xcr123. Clip-on and Belt loop versions are shown.
http://www.arcade-electronics.com/Se...poffs%20co-112 RIPOFFS CO/BL-112
http://www.arcade-electronics.com/Se...KeyWords=co-31 RIPOFFS CO/BL 31
http://www.arcade-electronics.com/Se...KeyWords=CO-94 RIPOFFS CO/BL 94 The velcro flap on the 94 is ok but a little short.
http://www.google.com/products/catal...ed=0CC0Q8wIwAw# SUREFIRE V11
I am using the V11 holster for the Surefire 9P which fits quite well and is the sleekest of the four, though it could be difficult to use with any but the trimmest lanyard. You can also cut the bottom out of a Surefire 6P holster, or, even better the Fenix TK-15 holster. As I mentioned, the best, most compact holster would be a lengthened version of that holster. Unfortunately it doesn't exist, but these are the next best .
I am looking forward to Selfbuilt's run time tests of this terrific light.
Brightnorm
selfbuilt
The main review post has been updated with the final review text.
The thread discussions have been partially restored from the search engine cache data (thank you tandem!). Basically, I was able to capture original p. 2, 3, 4, 6 and 7 from the cache. Pages 1 and 5 are all gone. If anyone has cache data from those pages, let me know and I will insert them.
Please carry on! :)
BSflashlight87
Great review, I just got this light and it's throw is very good, using it's small R5 led.
The light is very compact and has a great UI.
LOve it!:)
selfbuilt
Does the TD15 support TWO extender tubes, for a total of 4 CR123 primaries?
Thank you.
According the voltage specs (i.e. 3V-14V), you should be able to run 4x 3V primary CR123A safely. However, 4xRCR would be out of the question (i.e. 4x 4.2V would likely blow the circuit).
