wquiles
Well said. If done right, as you have, there is nothing wrong with a simple resistorred_robby said:I agree with you, if you're going to drive the lux at 700mA or higher then you would want to make sure you take care of the heat somehow, I dont need that much light from my dome, my lux is getting somewhere between 300mA-400mA
and it's plenty bright, better then stock (i wanted the lux for the color mostly, i like white better then yellow), the Nflex is a very nice driver and mod a mag did a nice job, but for my needs the $1 resistor worked pretty well.
This DeWalt 18V LED modification was completed on July of last year and it works awesome. Because of being LONG running and becuase of having a flexible neck, it is my most used work/project light. And yes, it is simply using resistors
Will
