MBentz
Got it today fivemega, thank you. I do have a quick question though. Is the spacer supposed to slide in the M6 body? If the light is pointed straight up, and I turn it so it's facing down, I can clearly hear the spacer moving.
Some included foam will stop the spacer tube from moving.I can clearly hear the spacer moving.
[SIZE=+2]Sore more M6 Deep Tail Cap Available.
Please check post #1 for next available number.[/SIZE]
When using protected batteries such as these current capability wouldn't be as good as IMRs but good to use with LEDs and low current incand bulbs.is there a difference between using a 26500 button top and non button top batteries? AW no longer makes 26500's.
I guess you don't have any more PVC tubes for these?
also what color are these? It's kind of hard to tell on my screen.
Sorry, no extra PVC but each kit comes with one PVC tube.
Tail cap is natural/grey HA pretty close to match M6 body.
Each M6 Deep Tailcap with Switch for $52 comes with one PVC tube.Do you have the PVC tube, if I buy one M6 Deep Tailcap with Switch?
